Using multiple drawing views
Command
Path
Shortcut
View bar
Enable Multiple View Panes
View > Multiple View Panes
M
To use multiple drawing views:
In any drawing view, select the command or click the View bar button.
The drawing area is divided into multiple view panes; the single view when the command is selected becomes the active view.
To set all panes to the same class visibilities, layer visibilities, and clip cube, select View > Multiple View Panes > Use Same Visibilities in All Panes. Deselect the command to set visibilities independently in each view pane.
Edit the drawing in the active view pane; to configure and draw in a different pane, click in the pane or on the pane title flag to make it active.
You can begin a drawing operation in the active pane and conclude it in another pane.
To return to a single view pane, select the command again.
The shortcut key to enable multiple view panes can be customized; see Modifying special shortcuts.
Concept: Multiple drawing views
Changing the multiple view pane layout
