Architect or LandmarkCreating hardscape components
Tool
Tool set
Hardscape
Site Planning
Hardscape components define the sections that make up a hardscape. Both the main area and the border components can have distinct components. For example, to indicate that a hardscape is made up of pavers, gravel, soil, and bedrock, define a component for each of these items to illustrate their location. Component appearance can be specified for cross-section views, and can be textured, creating realistic section views and rendered views, as well as accurate hardscape supply estimates. If a material resource is used to define a component, the material typically provides the fill, texture, physical attributes, and construction information needed for drawings, renderings, and reports. The area and volume of hardscape components can be calculated in worksheets; see Worksheet functions.
The overall thickness of a hardscape is equal to the sum of its components (the same is true for the border thickness and the border components). Component fill and pen style are only displayed in section viewports.
Use the Eyedropper tool to copy hardscape component settings from one hardscape to another (see Transferring attributes).
To define a hardscape component:
Do one of the following:
To define a component while a hardscape or hardscape style is being created, open the Draw 3D pane of the Hardscape Preferences dialog box and click the Main Area Components or Border Components button.
For a description of the parameters in the Hardscape Preferences dialog box, see Creating hardscapes.
To define or edit hardscape components for an existing, unstyled hardscape, select the hardscape and click Main Area Components or Border Components on the Object Info palette to open the Hardscape Main Area Components or Hardscape Border Components dialog box.
The Hardscape Main Area Components or Hardscape Border Components dialog box opens.
Parameter
Description
Preview
Displays a sectioned preview of the hardscape or border, including any defined components
Overall Thickness
Displays the thickness of the hardscape or border. The hardscape or border thickness is always determined by the thickness of its components; a hardscape or border always has one component by default.
Datum
Select whether the datum is applied to the top or bottom of the designated component; the indicator in the Datum column updates accordingly. A datum is the reference point for elevation settings; for hardscapes, it is fixed vertically (it does not change with any changes to the slab thickness or definition). One of the components is designated as the datum component.
Surface
Select whether the hardscape or border is of fixed thickness or has a tapered component to assist with drainage. Click in the Tapered column to designate the tapered component.
Components
Lists the components that form the hardscape or border, in order from top to bottom as displayed in the preview. To change the order of a component, click and drag within the # column.
If multiple components are selected, changing the order moves all selected components to the new location.
Datum
Click in the column to designate the datum component. An indicator in the column points towards the top or bottom, to show that the datum is placed on the top or the bottom of the component. To change the datum to be at the top or bottom, either click on the indicator to switch the placement, or click Top of component or Bottom of component in the Datum section of the dialog box.
Tapered
(Slab Drainage type)
If Tapered component is selected in the Surface section of the dialog box, click in the column to designate which component is tapered. The bottom surface of the designated component is flat, and the top surface is tapered to incorporate the drainage. All components above and below the tapered component are of uniform thickness to maintain the taper that the designated component brings to the overall slab.
Other Component settings
The remaining columns in the component list display the current settings for the hardscape or border, from the Component Settings dialog box
New
Opens the main area or border Component Settings dialog box to define the components of the hardscape or border
Edit
Opens the main area or border Component Settings dialog box to edit the attributes of one or more selected components; changes are made to all selected components. Alternatively, to edit a single component, double-click the component to open the dialog box.
Duplicate
Duplicates one or more selected main or border components; the duplicates are added to the component list right below the originally selected components
Delete
Deletes one or more selected main or border components; the main or border component thickness is adjusted accordingly
Below the Components list, click New to create a new component (or select a component to edit and click Edit).
The main area or border Component Settings dialog box opens. Specify the component thickness, name, and parameters.
Parameter
Description
Definition
Name
Provide a name for the component, which displays in the Components list in the hardscape Components dialog box
Class
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Object Class> to place the component attributes in the same class as the hardscape object.
Material
To use a material resource, select a material from the Resource Selector
Thickness
Specifies the component’s default thickness; the thickness of a hardscape is the sum of its components. A component must have a thickness greater than 0.
Section Fill
Specifies the component appearance in section views. If the component uses a material, the fill is set to the material’s fill, and the controls are disabled. Otherwise, select a fill style, or Class Style to set the fill attributes by class. Depending on the Style selected, select a color, pattern, or resource (hatch, image, gradient, tile).
Section Pen
Specifies the component appearance in section views. Select a pen style, or Class Style to set pen attributes by class. Depending on the Style selected, select a color, pattern, or line type resource.
Thickness
Select the line thickness; to use a custom thickness, select Set Thickness from the line thickness list (see Line thickness attributes)
Texture
Applies the selected texture to the component. If the component uses a material, the texture is initially set to the material’s texture, but this can be overridden. Select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or if the selected item's material texture was previously overridden, to revert to the material's texture.
The Object Info palette Render tab has additional texturing controls for existing objects; see Managing object textures from the Object Info palette and Textures on objects with components. Textures applied from the Object Info palette override the textures set here unless the texture is set by style.
Make All Attributes By Class
Sets all fill, pen, and texture attributes by class, except those that come from a material
Remove By Class Settings
Removes all class settings for fill, pen, and texture attributes; does not affect material definitions with attributes set by class
After you click OK, the Overall Thickness value changes to be determined by its components. As components are defined, they display in the preview. Click and drag a component in the # column to change its order. Determine which component is the datum component by clicking in the Datum column. Set the datum to the top or bottom of the component.
Concept: Resource libraries
The Attributes palette
Defining and editing tiles
Concept: Material resources
Using materials
Setting class properties
Setting class attributes
Creating hardscapes
