Curtain wall preferences
The Vectorworks program models the curtain wall frames, panels, and connections according to real-world architectural standards. Energy-related information specified for curtain walls is considered when conducting an energy analysis (Vectorworks Architect required). Doors and windows have special capabilities when they are inserted within curtain walls so that all the design elements work together.
Curtain walls consist of a repeating grid of frames and panels. From the Wall Preferences dialog box, specify the number of horizontal and vertical frames that make up one section of the curtain wall, and then specify the appearance of the frames and the panels within that grid. The defined section is repeated over the length and height of the wall.
Unstyled curtain walls can be drawn first, and the curtain wall parameters can be set later from the Object Info palette by clicking Curtain Wall Grid. The Curtain Wall Grid dialog box opens, to edit the parameters of the unstyled curtain wall. However, editing unstyled walls by this method may clear existing frames and panels, and recreate the curtain wall grid. See Concept: Editing guidelines for curtain wall grids.
Curtain wall preferences are set from the Wall Preferences dialog box (see Drawing walls). The parameters can be edited later from the Object Info palette. The Edit Wall tool manipulates individual frames and panels of the wall; see Editing curtain wall frames and panels.
Standard walls have different preferences; to design a standard wall, see Standard wall preferences.
Parameter |
Description |
Wall Style |
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing. If a selected wall style’s parameters are edited in the Wall Preferences dialog box, the wall style automatically changes to unstyled, indicating that the edited style must be saved as a new style to save changes (alternatively, the changes can be applied as an unstyled wall, and they are not saved). |
Save Preferences as Wall Style |
Saves the current preference settings as a new wall style. The Assign Name dialog box opens; enter a wall style name (see Creating wall styles). |
Wall Type |
Select whether to create a standard wall or a curtain wall. Curtain walls are described in this section. Standard walls are described in Standard wall preferences. |
Definition |
The definition allows only a regularly repeating grid, with the same panel attributes for all panels, and the same frame attributes for all frames in the same category. Frame and panel settings can be changed as descried in Editing curtain wall frames and panels, but these edits do not affect the underlying definition. See Concept: Editing guidelines for curtain wall grids to understand how the definition responds to edits. |
Displays a preview of the grid structure; the preview wall is drawn in a Front view |
Vertical/Horizontal Gridlines |
Use the list boxes and buttons to edit the grid structure as follows: Click Add to add a new gridline below the selected gridline. The new gridline has the same Spacing distance. Click the Spacing value of the selected gridline to edit it. Drag and drop the number in the # column to move the selected gridline. Click Delete to remove the selected gridline. |
Frame Settings |
Opens the Frame Settings dialog box, to set the type of frames and their appearance; see Setting curtain wall frame parameters |
Panel Settings |
Opens the Panel Settings dialog box, to set the type of panels and their appearance; see Setting curtain wall panel parameters |
Wall Thickness |
Sets the standard frame depth for the curtain wall. This value displays when determining the frame and panel settings, for reference. To avoid errors where walls join, keep the wall thickness and frame thickness values similar. |
Offset Reference |
Specifies the offset reference point for frame and panel offsets; the actual offset distances are set in the Frame Settings and Panel Settings dialog boxes |
Edit Wall Attributes |
Opens the Wall Attributes dialog box, to set the appearance and visibility of the curtain wall parameters; see Editing wall attributes. Some options apply only to standard walls, and they are not available for curtain walls. Opacity and drop shadow attributes are always set from the Attributes palette (see The Attributes palette). |
Insertion Options |
Height |
Height |
Directly sets the desired height of the wall. When the wall height is determined manually by this method, the Top Bound property of the wall is automatically set to Layer Elevation, and the Top Offset value is modified accordingly. When the top of the wall is bound by the layer wall height value, the wall height updates automatically. |
Top Bound |
Sets the vertical reference that determines the top of the wall. The Layer Wall Height value is set by the design layer (see Setting design layer properties). Additional options are available for the Vectorworks Architect and Landmark products. The top of the wall can be bound by one of the story levels defined for the story or the story above it. By setting the top of the wall to a level type, if the elevation of the associated story changes, the height of the wall changes automatically to match. The default curtain wall styles automatically assign a top bound level type to the wall, assuming that stories will be used in the file. However, this can be changed by selecting a different option. |
Top Offset |
Sets the offset of the top of the wall from its specified top bound height |
Bottom Bound |
Sets the vertical reference that determines the bottom of the wall; Layer Elevation is the only option available unless the Vectorworks Architect product is installed. Additional options are available for the Vectorworks Architect and Landmark products. The bottom of the wall can be bound by one of the story levels defined for the story or the story below it. By setting the bottom of the wall to a level type, if the elevation of the associated story changes, the height of the wall changes automatically to match. The default curtain wall styles automatically assign a bottom bound level type to the wall, assuming that stories will be used in the file. However, this can be changed by selecting a different option. |
Bottom Offset |
For the bottom of the wall, sets the offset from the layer elevation |
Caps |
Select whether a wall segment is capped at the start point, the end point, both ends, or has no caps at all |
Class |
Specifies the default class for the walls |
Curtain Wall Cut Plane |
Sets the height for the display of the Top/Plan appearance of the curtain wall; when the design layer cut plane is enabled (see Setting design layer properties and Wall display with design layer cut plane enabled, Vectorworks Architect required), the elevation of the curtain wall cut plane is set to the same value as that of the design layer, ensuring a uniform cut plane appearance for the layer |
Control Offset |
If using the Custom Control Line wall mode, enter the offset value for the control line |
Energos (Architect required) |
Energy analysis parameters for curtain walls are specified in the frame and panel settings. Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes. |
Textures |
Textures for curtain walls are controlled by the frame and panel settings |
Data |
Specify wall information. This information can be included in a wall style schedule. These parameters are optional; enter text only where desired. |
If these wall preferences should be saved as a wall style, click Save Preferences as Wall Style. See Creating wall styles.
A saved or selected wall style is saved as a resource in the file, and displays in the Resource Manager and in the Wall Style list on the Tool bar.
