Editing elevation benchmarks
To edit an elevation benchmark style, see Editing plug-in object styles.
To edit one or more elevation benchmark objects:
To access all editing options, select the object and edit the settings from the Object Info palette. For a styled object, you can use the Style list options to replace the style or convert the object to be unstyled if necessary.
If elevation benchmarks overlap, two settings in the Object Info palette can improve readability:
Use leader offset allows you to offset the leader line
Allow text objects to be moved allows you to move the elevation benchmark text, leaving the marker in place
To edit the layout, do one of the following:
Click Edit Marker Layout from the Object Info palette
Right-click the object and select Edit Marker Layout
Right-click the object and select Edit (or double-click the object). From the Select Edit Method dialog box, select the option to edit the layout
If your benchmarks show elevation above sea level, you can update the Project Elevation in the document setup to update all benchmark objects. (Architect or Landmark required)
When using the Reshape tool, also select related elevation benchmark objects, to maintain their position relative to the objects being reshaped.
