Design SuiteElevation benchmarks
Tool
Tool set
Elevation Benchmark
Dims/Notes
Use the Elevation Benchmark tool to indicate the height of objects in section and elevation drawings. Elevation benchmarks can be created in various contexts, to suit different design needs.
For a 2D drawing on a design layer, an elevation benchmark reports its Y value in relation to a specified reference elevation or control point.
For a 3D drawing, elevation benchmarks generally report their Z values, either as planar objects on a design layer, or as annotation objects in regular or section viewports. You can select different reference points, such as the ground plane, the design layer's Z value, or a custom elevation. If needed, benchmarks can report elevations with respect to sea level.
If a project has stories defined (Vectorworks Architect or Landmark required), you can link an elevation benchmark to a story level. These objects can be placed either on design layers or in viewport annotations. See Elevation benchmarks and stories.
A number of common elevation benchmark styles are provided in the Vectorworks resource libraries. If you require a different graphic standard, create a custom style.
Mode
Description
Elevation Benchmark at the End
Draws a leader line with the elevation benchmark at the end
Elevation Benchmark at the Beginning
Draws a leader line with the elevation benchmark at the beginning
Elevation Benchmark with no Leader
Draws the elevation benchmark with no leader line
Benchmark Datum
Specifies how the elevation value is calculated
Offset
If Benchmark Datum is set to a story level, offsets the elevation benchmark from the story level elevation by the specified amount
Style
Opens the Resource Selector to select a resource for placement; double-click a resource to activate it
Preferences
Sets the default parameters for the tool; see Elevation benchmark settings
Adding an elevation benchmark
Editing elevation benchmarks
