 Renumbering ConnectCAD objects
  | Command | Workspace: Path |
| Renumber ConnectCAD Objects | Design Suite: Entertainment > ConnectCAD Drawing Spotlight: Spotlight > ConnectCAD Drawing ConnectCAD: ConnectCAD > Drawing |
Renumbering ConnectCAD objects is useful when designing a new system with numbering that depends on the object names or IDs. This command renumbers the object name, Rack ID for 3D equipment racks, or Room ID for layout rooms, and the Display Tag suffix for devices and sockets. For existing systems, use caution when renumbering, since the associated cable numbers should match the cable numbers that have already been installed on site. Optionally, this command adds a custom prefix to the object name, Rack ID, or Room ID, and/or the Display Tag for devices or sockets.
To renumber ConnectCAD objects in the drawing:
Select objects of the same type to renumber. You cannot renumber a mixture of object types.
Selected devices are renumbered in the order in which they were drawn.
Select the command.
The Labeling Options dialog box opens. Select either numeric or alphabetical labeling.
| Parameter | Description |
| Numeric |
| Select the starting number; if the desired number is not in the list, select Custom to specify a custom start number in the Add New Start Number dialog box | |
| Increment by | Select the increment interval |
| Format | Select the number of leading zeros |
| Delimiter | Select a delimiter character to place before the number |
| Alpha |
| Start | Select the starting letter |
| Case | Choose either upper or lower case letters |
| Delimiter | Select a delimiter character to place before the letter |
| Prefix (Optional) |
| Name | Adds a prefix to the object name, Rack ID, or Room ID |
| Display Tag (device or socket required) | Adds a prefix to the device or socket Display Tag |
| Numbering Direction | Select the numbering direction. The stacking order of the objects is usually the order in which they were added to the drawing. |
| Example | Displays a preview of the selected labeling options |
