Adding symbol geometry to a slab
Command |
Workspace: Path |
Add 3D Object to Slab |
Design Suite, Architect: AEC Landmark: Landmark > Architectural Spotlight: Spotlight > Architectural |
A symbol or plug-in object, such as a skylight, can be inserted into a slab. The symbol geometry modifies the slab while inserting itself into the slab, similarly to the way a door or window is inserted into a wall. Symbols with a hole-cutting component (hole component) cut the slab.
To add a 3D symbol to a slab:
Select both the slab and the 3D symbol.
Select the command.
The symbol is inserted into the slab.
The symbol can only be selected and modified in Edit Modifiers mode.
