Edit group and object visibility options
From the Window menu, select Edit Group and Object Visibility Options to access the following commands. These options are also available from the Quick Preferences menu.
Menu command |
Description |
Use Large Buttons |
In object editing mode, shows a large button for exiting the mode. The button label varies depending on the object (such as Exit Group or Exit Symbol). When objects in the drawing area are hidden, shows a large button for making objects visible again, with the label Unhide Objects. |
Use Small Buttons |
<Esc><Esc> Exits Group |
In object editing mode, pressing the Escape key twice exits the mode |
<Esc><Esc> Does Not Exit Group |
In object editing mode, pressing the Escape key twice does not exit the mode |
In object editing mode, shows a small button for exiting the mode.
When objects in the drawing area are hidden, shows a small button for making objects visible again.
