Rotating the 3D view
To rotate the 3D view, either use the Rotate View tool and the mouse, or specify rotation values with the Rotate 3D View command.
When Two-Point Perspective is enabled for a perspective projection (see Projection), it remains active until the view moves too near the top or bottom of the model to maintain two-point perspective without distortion. You cannot roll the view (rotate the view sideways) when Two-Point Perspective is enabled.
Rotating with the mouse
Tool
Tool set
Shortcut
Rotate View
Visualization
Shift+W
The Rotate View tool rotates the view clockwise or counter-clockwise in 3D.
To control the movements of the Rotate View tool, drag the mouse or click one of the mode buttons. The first three Tool bar buttons set the center of rotation. The last two modes perform precise, incremental rotation movements in the direction specified.
Mode
Description
Rotate Around Object Center
Uses the center of selected objects as the rotation center
Rotate Around Active Layer Plane Center
Uses the center of the active layer plane as the rotation center
Rotate Around Working Plane Center
Uses the origin of the current working plane as the rotation center
Rotate Clockwise/Counter-Clockwise
As an alternative to moving the cursor to set the rotation direction, instantly rotates the view clockwise or counter-clockwise
To rotate the 3D view:
Click the tool and modes.
Click the drawing and drag while holding the mouse button. Move the cursor to rotate the view in the direction of the cursor movement. Release the mouse button to stop the rotation. Alternatively, use the tool modes to control clockwise/counter-clockwise movement.
Mode
Mouse movement/key
Description
Move left or right
Rotates about the screen Y axis (or the screen Z axis if the cursor is at the perimeter of the drawing)
Move up or down
Rotates about the screen X axis (or the screen Z axis if the cursor is at the perimeter of the drawing)
Rotate Clockwise
Each click rotates the view in a clockwise direction about the selected center of rotation
Rotate Counter-Clockwise
Each click rotates the view in a counter-clockwise direction about the selected center of rotation
When the Rotate View tool is in use, the Data bar displays the following information to help orient the view.
Data bar
Description
Azimuth
Displays the active layer plane angle (in degrees) between the positive X axis and the direction from the selected center of rotation to the viewer
Elevation
Displays the angle (in degrees) between the selected center of rotation and the plane that is parallel to the active layer plane and passes through the view origin
Roll
Displays (in degrees) the amount of rotation about the selected rotation center
Rotating precisely
Command
Path
Rotate 3D View
View
The Rotate 3D View command provides a precise way to rotate the 3D view. Enter rotation values directly, or rotate the view in increments. A preview displays the rotation movements before the actual view is rotated.
Select the command.
The Rotate 3D View dialog box opens.
Parameter
Description
Parameters are absolute
Starts the view rotation from a top (absolute) view
Parameters are relative
Starts the view rotation from the current view
Interactive Rotate
+, - X/Y/Z buttons
The "+" and "-" buttons for each axis rotate the view by the increment specified
Angle Increment
Specifies the rotation increment (in degrees) for the interactive rotation buttons
Rotate By Value
Rotation on X/Y/Z
Specifies the rotation value (in degrees, minutes, and seconds) for the X, Y, and/or Z axes
Simulating movement
Concept: Working planes
