SpotlightAdding loads
Tool
Tool set
Rigging Load
Rigging/Braceworks
Many Spotlight objects are automatically considered to be either a point load (such as lighting devices and projectors) or a distributed load (such as soft goods, video screens, and LED walls). A generic point load or distributed load can be added with the Rigging Load tool. See Concept: Attaching loads to rigging objects.
After placement, the generic load symbol can be switched to use a realistic graphical symbol instead.
Mode
Description
Point Load
Inserts a point load
Distributed Load
Inserts a distributed load
Load Category
Specifies the load category, which is important for calculations (Braceworks required)
Weight
Sets the weight of the load. For a point load, this value is the total weight. For a distributed load, this value represents either the distributed weight or the total weight, depending on the selected weight mode.
Non-Rotated Label
(point load only)
Does not rotate the label text
Perpendicular Label
(point load only)
Angles the label text 90 degrees from the rigging object
Angled Label
(point load only)
Angles the label text 45 degrees from the rigging object
Distributed Weight
(distributed load only)
For distributed loads, the specified Weight represents the distributed weight
Total Weight
For distributed loads, the specified Weight represents the total weight
Automatic Numbering
When toggled on, enables automatic numbering as objects are placed
Automatic Numbering Preferences
Sets the automatic numbering preferences
Load Settings
Opens the Load Settings dialog box, for creating and selecting saved load sets
Creating and selecting load sets
Inserting a point load
Inserting a distributed load
Numbering Spotlight objects
