SpotlightInserting a distributed load
Mode
Tool
Tool set
Distributed Load
Rigging Load
Rigging/Braceworks
To insert a distributed load:
Click the tool and mode.
To automatically number loads as they are placed, click Automatic Numbering, and then click Automatic Numbering Preferences; see Numbering objects at placement.
Do one of the following:
To use a saved set of load properties, click Load Settings on the Tool bar and select the load set.
If not using a saved load set, specify the Load Category; select either Distributed Weight or Total Weight mode and enter the load’s Weight. If entering the distributed weight, enter values with a slash between the weight and the distance (500/10 indicates 500 pounds per 10 feet of length, for example).
Move the mouse to the rigging object where the distributed load is to be hung.
Valid connecting structures are highlighted.
Click to set the load object's start point.
Click to set the end of the segment and the beginning of the next. Continue drawing segments in this manner until the load object is complete. Double-click to finish creating the load object. The distributed load polyline cannot extend beyond the rigging object.
The distributed load is placed at the centerline of the rigging object.
In Top/Plan view, the distributed load label displays. It can be moved by clicking and dragging the label control point.
The parameters can be edited later from the Object Info palette.
Parameter
Description
Load Category
Specifies the load category, which is important for calculations (Braceworks required)
Length
Displays the length of the distributed load
Show Label
Displays the label in Top/Plan view
Scale Distributed Load
Automatically scales the distributed load with the drawing scale, so that larger loads are more visible
Select Similar Objects
Objects of same name
Selects load objects with the same Load Name parameter
Objects of same load category
Selects load objects with the same Load Category parameter
Objects of same total weight
Selects load objects with the same Total Weight parameter
Objects of same distributed weight
Selects load objects with the same distributed weight
Load information
Load information is used for Braceworks calculations and reports (Braceworks required)
Include in Calculations
Includes the load in Braceworks calculations; deselect to exclude the load from participating in structural calculations.
Once calculated, a load that causes the truss to tilt displays a label. If enabled in the Braceworks preferences, when the truss tilts past the specified threshold, a tilting arrow object also displays. Adjust the scale of a selected tilting arrow from the Object Info palette.
Load Group Name
Displays the selected load category
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations
Distributed Weight
Enter the distributed weight of the object
Total Weight
Enter the total weight of the object
Position
Displays the name of the associated rigging object, if the load is attached.
For methods to attach loads, see Making the attachment.
Adding a distributed load automatically
Command
Workspace: Path
Add Distributed Load at Selection
Design Suite: Entertainment > Rigging/Braceworks
Spotlight: Spotlight > Rigging/Braceworks
If the length of a distributed load is not critical, a distributed load can be added automatically to the rigging objects in the drawing.
To add a distributed load automatically:
Select the rigging object where the distributed load will be placed. When more than one rigging object is selected, a distributed load is placed on each one.
Select the system to easily select more than one rigging object, and automatically add the same load to each.
Select the command.
The Load Settings dialog box opens, for Creating and selecting load sets. Select a load set, or enter load parameters and select the <Active Settings> set.
A distributed load is placed along the length of each rigging object.
Concept: Attaching loads to rigging objects
Numbering Spotlight objects
Inserting a point load
Adding loads
