ConnectCADRenumbering ConnectCAD objects
Command
Workspace: Path
Renumber ConnectCAD Objects
Design Suite: Entertainment > ConnectCAD Drawing
Spotlight: Spotlight > ConnectCAD Drawing
ConnectCAD: ConnectCAD > Drawing
Renumbering ConnectCAD objects is useful when designing a new system with numbering that depends on the object names or IDs. This command renumbers the object name, Rack ID for 3D equipment racks, or Room ID for layout rooms, and the Display Tag suffix for devices and sockets. For existing systems, use caution when renumbering, since the associated cable numbers should match the cable numbers that have already been installed on site. Optionally, this command adds a custom prefix to the object name, Rack ID, or Room ID, and/or the Display Tag for devices or sockets.
To renumber ConnectCAD objects in the drawing:
Select objects of the same type to renumber. You cannot renumber a mixture of object types.
Selected devices are renumbered in the order in which they were drawn.
Select the command.
The Labeling Options dialog box opens. Select either numeric or alphabetical labeling.
Parameter
Description
Numeric
Start
Select the starting number; if the desired number is not in the list, select Custom to specify a custom start number in the Add New Start Number dialog box
Increment by
Select the increment interval
Format
Select the number of leading zeros
Delimiter
Select a delimiter character to place before the number
Alpha
Start
Select the starting letter
Increment by
Case
Choose either upper or lower case letters
Delimiter
Select a delimiter character to place before the letter
Prefix (Optional)
Name
Adds a prefix to the object name, Rack ID, or Room ID
Display Tag
(device or socket required)
Adds a prefix to the device or socket Display Tag
Numbering Direction
Select the numbering direction. The stacking order of the objects is usually the order in which they were added to the drawing.
Example
Displays a preview of the selected labeling options
Numbering circuits
Concept: ConnectCAD devices
Adding sockets, loops, and terminators
Placing connector panels
Placing terminal panels
Placing jackfields and linked jackfields
Placing distribution amplifiers
Placing external connections
Placing equipment
Placing equipment racks
Placing a rack frame
Creating a layout room
ConnectCAD
