SpotlightPrevisualization with Showcase
Command
Workspace: Path
Start Showcase
End Showcase
Design Suite: Entertainment > Showcase
Spotlight: Spotlight > Showcase
Showcase palette: Turn Showcase on/Turn Showcase off
Turning on Showcase, whether from the palette or from the Start Showcase command, activates a special Showcase rendering mode for the drawing or the active view pane, with the settings established in the Showcase preferences. Alternatively, you can apply a Showcase render style from the Current Render Mode menu on the View bar; if a Showcase render style is applied, a purple border displays. The DMX objects are connected to the specified physical or virtual console and ready to receive signal input, or ready to play a selected DMX recording from the Showcase palette.
To turn off Showcase and return to the drawing window, click Turn Showcase off from the Showcase palette, or select the End Showcase command. Moving objects return to their home positions.
While Showcase is active:
If you were in Top/Plan view when selecting the command, the view switches to Top.
Lighting devices, DMX-controlled trusses or objects, and video screens are controlled by their DMX connections and video sources, or by the DMX recording. Lighting devices and trusses may move drastically depending on their DMX data for position and orientation.
The active layer displays in either Shaded rendering mode, based on the Showcase preferences settings, or in the applied Showcase render style. Light brightness, color, spread, pan, tilt, gobo textures, and moving gobo wheel effects are shown as specified.
Moving objects cannot be selected while Showcase is active.
Move sliders on the connected console, or play a DMX recording; lights move and change to match the input. Vectorworks viewing tools, such as Pan, Zoom, Flyover, Walkthrough, and Onscreen View Control adjust the view with variable framerates during the operations.
Lighting devices respond to DMX data consistent with the GDTF file specification they are assigned to. Light brightness, color, spread, pan, tilt, gobo textures, and moving gobo wheel effects are shown.
If there's an issue with the network data stream, verify that the network is functioning correctly with the indicators in the Showcase palette.
Record the actions with the Showcase palette for playback later.
Actions that stop the simulation:
Changing the visibility of a class or layer that contains moving objects.
Changing the view to Top/Plan or switching to a different render mode.
Switching to a sheet layer.
Entering a group or symbol definition.
Modifying moving objects, including modifying objects from another view pane.
Concept: Showcase
Setting Showcase preferences
The Showcase palette
Workflow: Previsualization with Spotlight
Selecting a video source for Showcase
