SpotlightSetting Showcase preferences
Command
Workspace: Path
Showcase Preferences
Design Suite: Entertainment > Spotlight Settings
Spotlight: Spotlight > Spotlight Settings
Select the default Showcase render style to use when Showcase is active, associate a physical or virtual console that produces DMX data to the Vectorworks session, and optionally specify PSN origin coordinates.
To set Showcase preferences:
Select the command.
The Showcase Preferences dialog box opens. Set the default Showcase parameters.
Parameter
Description
Render Style
Select the file's default Showcase render style for use when Showcase is active; custom Showcase render styles in the active file and default Showcase render styles in Vectorworks libraries are available.
You can change the render style and/or interactively change the current render options when Showcase is active, as described in The Showcase palette.
Edit Options
Opens the Showcase Render Options dialog box, to edit a render style or the unstyled render options; see Showcase render style.
DMX Data Provider
Associate Showcase with a physical or virtual console that produces DMX data; select the communication protocol used to control the intelligent lighting fixtures
Options
(MA-Net3 only)
Opens the DMX Data Provider Options dialog box, to specify the MA-Net3 protocols. Select the Network Interface that provides the connection to the console, and the MA-Net3 Version. If you select the Updater version, the MA-Net3 Updater dialog box opens automatically when exiting the preferences, to update the MA-Net3 version.
PSN Origin
PosiStageNet (PSN) is an open source protocol that allows both pre-programming and active control of object movement and rotation. Specify the X,Y, and Z PSN origin world coordinates, to align the automation origin with the Vectorworks internal origin. See PSN and DMX transforms for scene objects.
Connecting to MA-Net3
Using the MA viz-key, you can connect to a grandMA3 console or onPC computer and join an MA-Net3 session. First, install the viz-key driver and update Showcase preferences to communicate with the specific version of grandMA3 software that you will use for visualization. Once the update is complete, you can select the desired grandMA3 software version in Showcase, and connect to the MA-Net3 network.
The grandMA3 must use the same grandMA3 software version to visualize a show.
Configuring the viz-key connection
To install the viz-key driver and update Vectorworks to communicate with your grandMA3 software:
Select MA-Net3 for the DMX Data Provider in the Showcase Preferences dialog box.
Click Options.
The DMX Data Provider Options dialog box opens. Select Updater from the MA-Net3 Version list.
The MA-Net3 Updater dialog box opens automatically when exiting the preferences, to update the MA-Net3 version.
Follow the instructions for installing and updating the viz-key driver in the following article: forum.vectorworks.net/index.php?/articles.html/articles/connect-grandma-to-vision-2021-r837/.
Once you have run the updater for the grandMA3 software, that version becomes an option in the Select MA3 Software Version dialog box, as described in the following section.
Joining an MA-Net3 session
Once you have completed the steps in the previous section, Showcase can join an MA-Net3 session.
To join an MA-Net3 session:
Click Options.
The DMX Data Provider Options dialog box opens. Select the desired version of grandMA3 software from the MA-Net3 Version list.
Follow the instructions for connecting to specific versions of the grandMA3 software in the following article: forum.vectorworks.net/index.php?/topic/45676-dmx-connectivity-articles/
Previsualization with Showcase
Concept: Showcase
