Creating and editing viewport styles
Create a viewport style to lock some object parameters while leaving others variable. Viewport styles function similarly to plug-in object styles, but have some specialized functionality based on the specific use requirements of viewports; for more information, see Viewport styles and Concept: Plug-in object styles.
To create or edit a viewport style do one of the following:
Right-click on an unstyled viewport, and select New Viewport Style from Unstyled Viewport from the context menu.
From the Object Info palette of an unstyled viewport, select New Viewport Style from Unstyled Viewport in the Style list.
From the Resource Manager, click New Resource, and then select Viewport Style in the Create Resource dialog box.
If the Resource Manager is filtered to show only viewport styles, click New Viewport Style.
Right-click on a styled viewport and select Edit Viewport Style from the context menu.
From the Object Info palette of a styled viewport, select Edit Style from the Style list.
From the Resource Manager, right-click a viewport style and select Edit from the context menu.
Alternatively, to change a viewport's styled parameters without editing the style, either right-click the viewport and select Convert to Unstyled from the context menu, or select Convert to Unstyled from the Style list on the Object Info Palette. The parameter values remain the same, but they can be edited.
The Viewport Style or Edit Viewport Style dialog box opens.
Editing a viewport style affects every viewport in the file that uses that style.
Parameter
Description
Style Name
Enter the name, which must be unique in the file
Filter by Type
Filters the available parameters depending on the selection. Select whether to create a style using the parameters for a standard viewport, a section/interior elevation viewport, or a horizontal viewport (Design Suite product required for the section viewport types). To create a style for use with detail viewports, select the type that matches the view the detail is cropped from. This filter also affects which related dialog boxes can be accessed and set by style.
All by Style
Toggles all parameters in the dialog box, and in related dialog boxes, to by style or by instance; these settings can be changed individually as needed
By Style/Instance
For each parameter, toggle to the desired setting. Parameters set by instance use the provided settings as the defaults when the style is applied to a viewport, but they can be edited for each individual viewport.
Click By Style/Instance beside the button that opens a related dialog box to set all the parameters on that dialog box by style or by instance, or open the dialog box and set each parameter's style/instance setting individually. If the individual parameters are set differently, the by style/instance state displays as indeterminate on the Viewport Style and Edit Viewport Style dialog boxes.
Parameters
Set the value for each parameter. Many of the parameters are the same as when creating a viewport, but some, such as lighting options, are available only from the Object Info palette after a viewport is created. When a render style is selected for the background render mode, the background render settings and lighting options are controlled by the render style, and can't be edited from the viewport style; see Render styles. For more information about the parameters available for a particular viewport type, see the topics linked below.
A viewport style can be applied to any viewport, on a sheet layer or design layer (Design Suite product required for design layer viewports). When the style is used for a particular viewport, only the pertinent parameters are applied.
Creating sheet layer viewports
Creating a design layer viewport from an internal design layer
Creating a vertical section viewport
Creating a horizontal section viewport
Viewport properties
The viewport style is saved as a resource in the file, and can be shared from the Resource Manager like any other resource.
Applying viewport styles
Once a viewport style is created, you can select it from the Resource Selector when you create a viewport. You can apply a style or change the style for an existing viewport from the following locations:
Object Info palette Style list
Resource Manager
Organization dialog box Viewports tab
Navigation palette Viewports tab (Design Suite product required)
Eyedropper tool
Concept: Types of viewports
Viewport styles
Modifying viewports
Custom plug-in object styles without catalog options
Editing plug-in object styles
Concept: Resource libraries
Resource Manager
