Creating plant styles from a list
Command |
Workspace: Path |
Create Plant Styles from List |
Design Suite: AEC > Plants Landmark: Landmark Landmark Style Manager, Create Plant Style |
Plant data in a spreadsheet can be imported into Vectorworks Landmark, and used to batch create plant styles by mapping the data to the plant style parameters and to record fields. These plant styles can then be edited, including attaching appropriate graphics, in the Landmark Style Manager or the Edit Plant Style dialog box. This process can be used to efficiently create an entire custom library of hundreds or thousands of plants, with data appropriate to your region.
There are many ways to create plant styles. For an overview, see Concept: Plant styles.
To create plant styles from a list:
Select the command.
Navigate to and select the spreadsheet with data to import. Make sure the spreadsheet has column headers before you select it for import, or it may be difficult to map the data.
The Create Plant Styles from List dialog box opens.
Parameter |
Description |
Saved Settings Options |
See Using saved sets to save and apply saved settings |
Source File Format |
Select the imported file type; if the file is neither an Excel spreadsheet nor a tab-delimited file, select Other and specify the delimiter character |
Plant Data |
Source Data Units |
Select the units of measurement used by the source file; the same unit must be used for all dimensions |
Specify Plant Style Name |
To create the naming formula used for plant styles, select whether to automatically populate the Main Name Field with the plant's Latin name, common name, or plant tag ID; if desired, select a prefix and suffix to be appended to the name |
Data mapping list |
Some of the data is automatically mapped to fields in the Vectorworks plant style. For unmapped data, or to change the default mapping, select the plant style parameter from the Target Parameter list to map the source data. Each mapped parameter's type displays for reference but can't be edited. If you are both creating plant styles and adding data to a plant catalog by selecting Add data to catalog, two target columns display; map the data to each separately. The Target Parameter drop-down includes only parameters that aren't already mapped to a source data field, to prevent accidental double-mapping. |
Import Options |
Create plant styles in active document |
Creates plant styles in the active file |
Add data to catalog |
Adds data to an existing plant catalog; select the catalog |
2D graphic Resource Selector |
Select the 2D graphic to be used for all plant styles created from the list; this can be a 2D symbol from the default library or a 2D symbol you created. The graphics can be replaced or edited later. |
Select the source file and import settings, complete the name formula, and map the data to plant style parameters.
Plant styles are created based on the imported data; they are available in the Resource Manager and Resource Selector for the current file. The plant styles should be saved in a user or workgroup library, and can be shared with other files and other users, as described in Creating custom resource libraries and Exporting resources.
After the plant styles are created, you can view and edit them in the Landmark Style Manager or in the Edit Plant Style dialog box; see Landmark Style Manager and Plant settings for editing plant parameters, and Custom plug-in object styles without catalog options for how to set the by style/instance settings. You can also view and edit them from the Resource Manager.
