Architect or LandmarkEditing hardscape objects
There are several different ways of editing hardscape objects, depending on the type of hardscape and the desired outcome.
Modification
Description
Editing the hardscape properties of an individual instance
Click Hardscape Settings from the Object Info palette to edit a selected object.
With Use extended content browsing selected on the Hardscape Preferences dialog box, click Hardscape Style on the Tool bar. The Select Hardscape Style dialog box opens; click a resource to edit by instance settings; see Hardscape preferences
Use the Attributes palette for existing unstyled hardscapes or for applicable "by instance" parameters.
Editing hardscape styles
Landmark Style Manager and Editing hardscape styles
Adding a slope to a planar pad hardscape
Click Set Slope Direction from the Object Info palette; see Hardscape preferences
Reshaping the hardscape or path
Reshaping a hardscape object
Aligning hardscapes with surrounding geometry
Aligning hardscapes or modifiers with existing geometry
Modifying an aligned surface type
Editing aligned hardscapes or modifiers with surface modifiers
Editing aligned hardscapes or modifiers with profile lines
Converting a hardscape configuration
Converting a hardscape object to different configuration
Editing hardscape fills and joint patterns
Creating a section view of a hardscape
Workflow: Creating a section view of a hardscape
Modifying hardscape tag appearance
Hardscape tag appearance
