Saving a file
Command |
Path |
Shortcut |
Save Save As Save a Copy as Save All |
File |
Save: Ctrl+S (Windows) and Cmd+S (Mac) Save As: Ctrl+Shift+S (Windows) and Cmd+Shift+S (Mac) |
To save a file do one of the following:
To save the current file, select the Save command.
To save the file with a different name, select the Save As command.
To save a copy of the file and continue to edit the original file, select the Save a Copy as command.
To save the file as a template for future files, see Concept: Templates.
To save all open files, select the Save All command.
Save a file to both your the local Vectorworks Cloud Services folder and the cloud to automatically sync changes made to the file in either location, and facilitate sharing the file with others. See Concept: Using Vectorworks Cloud Services.
Automatically saving files
The autosave feature automatically saves the current file after either a specified number of minutes or a specified number of operations, as defined in the Autosave and Backup pane of the Vectorworks Preferences dialog box. See Vectorworks preferences: Autosave and Backup pane for more information.
If the Confirm before save preference is selected, a confirmation dialog box opens before the autosave is performed. The information that displays in this dialog box depends on the settings selected in Vectorworks preferences.
Parameter |
Description |
Yes |
Saves the file; if the document has not been saved, the Save dialog box opens to name the file first |
No |
Cancels the save operation and resets the autosave counters; select Don't autosave this document for the remainder of the session to disable the autosave feature for the active document for the remainder of the session |
Settings |
Opens the Vectorworks Preferences dialog box to edit the autosave parameters |
When the save is complete, the message Autosave complete displays in the lower right corner of the window; the message clears when you click the mouse.
Locating saved files
Once a file has been saved, you can locate it in the Finder (Mac) or File Explorer (Windows).
To find a file's location:
Right-click on a document tab and select Locate Document.
