Design SuiteEditing the current data visualization
Command
Path
Edit Data Visualization
View bar
Viewport Object Info palette
The Edit Data Visualization command edits the currently applied visualization or visualization set. To edit other visualizations, right-click a visualization/set in the Resource Manager's Resource viewer pane, and select Edit from the context menu.
The Data Visualization menu is only available from the View bar when a design layer is the active layer.
Edits apply to the design layer, saved views, viewports/viewport styles, and other files that use the same visualization.
To edit the current data visualization:
Select the command.
The Edit Data Visualization or the Edit Data Visualization Set dialog box opens.
Edit the visualization parameters as described in Creating a data visualization or Creating a data visualization set.
You cannot create a new visualization by changing its name; this simply renames it. Instead, create a duplicate of the visualization with a different name and edit it.
Edits apply globally to the design layer and to any saved views and viewports/viewport styles with the visualization applied.
Applying a data visualization
Viewing the drawing by data or by attributes
