Spot00056.pngLighting Device Properties
Instrument (or accessory) parameters can be viewed and edited from the Object Info palette. The parameters that display on the Shape tab of the Object Info palette depend on the settings made in Spotlight preferences; see Specifying Lighting Device Parameter Display.
Parameters can also be edited from the Lighting Device dialog box; see Changing Device Properties. Change advanced light properties, including turning the associated light source on, by editing the light source embedded within the instrument; see Advanced Light Properties.
For a custom instrument symbol without an information record attached, enter the required instrument object parameters (see Attaching the Light Info Record and Light Info Record M). An entry is not required for every field.
For instruments and accessories, do not provide a name on the Data tab. The instrument or accessory Unique ID Number (UID) is automatically entered and must be used as the instrument or accessory name.
Editing Lighting Instruments
Changing the Instrument Label Legend
Spotlight Setup
Editing Vision Data
Exporting Vectorworks Spotlight Data
vectorworks.net
