DesignSeries.pngModifying Section Viewports and Section Lines
Section viewports can be modified, cropped, annotated, and updated, similarly to sheet layer viewports. See Modifying Viewports and Updating Viewports.
The appearance of a section viewport, including an interior elevation viewport, can be completely customized, from the items it displays to the attributes of those items. Copies of a section viewport on a sheet layer can look completely different. Changes to a section viewport’s appearance can be made by several methods; after changes are made, update the section viewport by clicking Update from the Object Info palette.
Modification
Method
Description
Change the section view
Click Advanced Properties from the Object Info palette of a selected section viewport, and modify the section view from the Extent tab
Advanced Section Viewport Properties
Change the view attributes
Click Advanced Properties from the Object Info palette of a selected section viewport, and modify the attributes of the view from the Attributes tab
Change the view direction of the section line (not available for interior elevation viewports)
Click Reverse Direction from the Object Info palette of a selected section viewport
Viewport Properties
Change the cross section appearance for sectioned items (not available for interior elevation viewports)
The cross section appearance is set by the Section Style class. Edit the class to change the appearance of sectioned items. If the Section Style class is made invisible, the cross sections are not displayed.
Setting Class Properties
Override the layer settings from the design layer
Click Layers from the Object Info palette of a selected section viewport, and override the layer properties.
Unlike a regular sheet layer viewport, the design layer stacking order in the section viewport cannot be changed.
Changing the Layer Properties of Sheet Layer or Design Layer Viewports
Override the class settings from the design layer
Click Classes from the Object Info palette of a selected section viewport, and override the class properties of “by class” objects
Changing the Class Properties of Sheet Layer or Design Layer Viewports
Change the location of the section line
Change the location of the section line with the Selection tool, and update the section viewport
Modifying Section Lines Graphically
Create section viewports from unlinked section lines
Select the unlinked section lines and then select the Create Section Viewport command to create section viewports from the section lines
Creating Section Viewports from Unlinked Section Lines
Add additional section line instances to design layers or viewports
Click Section Line Instances from the Object Info palette of a selected section viewport, and specify the design layers or viewports where section line instances should display
Change the section line length, position, or type
Change the section line with the Selection tool or the Reshape tool, and update the section viewport
Change the depth of a finite section
The depth can be changed graphically or by modifying the Depth Range in the Advanced Properties of the section viewport
Modifying Section Lines Graphically, or Advanced Section Viewport Properties
Modifying Viewports
Viewport Properties
Viewport Status
Updating Viewports
vectorworks.net
