To insert a door in Vectorworks Fundamentals:
Insert a door symbol from the Resource Manager (see Inserting Symbols). The direction of a door inserted in a wall can be changed later by clicking Flip from the Object Info palette or from the context menu.
The Door tool is available for Vectorworks Fundamentals software but is not present in the Fundamentals workspace. It can be added to the Fundamentals workspace (see Customizing Workspaces) and subsequently used to insert door objects.
Click the Settings button from the Object Info palette to open the Door Settings dialog box. Select each pane and specify the door parameters. Click OK to set the door parameters and close the dialog box.
Several features of the door are described as “interior” or “exterior.” These include trim and wall-wrap parts. These elements are determined based on the internal and external faces of the wall. The left side of the wall (as viewed along the wall direction) is always “exterior,” and the right side is “interior” (see Wall Direction). Flipping the door does not flip these elements.
Creating Plug-in Object Styles allows you to create plug-in objects with a combination of parameters that are determined by the style or by instance. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing.
3D Visualization options are not enabled for the Opening Configuration.
Jamb options are not enabled for the Opening Configuration.
Leaf options are not enabled for the Opening Configuration.
Lights options are not enabled for the Opening Configuration.
Transom options are not enabled for the Opening Configuration.
Trim options are not enabled for the Opening Configuration.
Hardware options are not enabled for the Opening Configuration.
Kick Plates options are not enabled for the Opening Configuration or for curtain wall doors.
The visibility of the overall 3D door is controlled by the Class setting from the Object Info palette; part settings are controlled from the Door Settings dialog box.
Certain data fields represent calculated values and cannot be edited; as a result, the Field Name and Field Value appear dimmed for those data fields.
