The Line into Segments command converts a selected line into the indicated number of equal length segments. The original line can be converted, or an identical line placed on top of the original and converted.
To convert a line into segments:
Select the line to be converted.
Select Modify > Drafting Aids > Line into Segments.
The Line into Segments dialog box opens.
Set the parameters and click OK to draw either a new segmented line or convert the selected one.
