Spot00001.pngSetting Preferences
Set up cable preference settings prior to creating cables.
Setting Cable Preferences
Command
Path
Cable Preferences
Spotlight > Cables
The Cable Preferences command sets default cable lengths and offset distances.
To set up cable preferences:
Select the command. The Cable Preferences dialog box opens.
Setting Circuit Data Assignment Preferences
Command
Path
Circuit Assign Preferences
Spotlight > Cables
By default, the Assign Multicable Circuits command assumes that the multicable circuit information is to be assigned to lighting devices. However, there are other situations where multicable information needs to be assigned to speakers or other types of stage objects. The Circuit Assign Preference command determines how to assign values to objects that are not lighting devices.
To set up multicable circuit preferences:
Select the command. The Circuit Assign Preferences dialog box opens.
Setting Multicable Jumper Preferences
Command
Path
Spotlight > Cables
The Multicable Jumper Preferences command determines default placement options when placing multicables with jumper cables.
To set up multicable jumper preferences:
Select the command. The Multicable Jumper Preferences dialog box opens.
Assigning Circuit Information
Inserting Feeder Cables
Inserting Multicables
Inserting Jumper Cables
Inserting Data Cables
