Spot00002.pngInserting Feeder Cables
Mode
Tool
Tool set
Modes for the Polyline Tool
Feeder Cable
Lighting
On a show site, feeder cables are usually set up first. These carry power from the building service or generator to the distribution systems that power the lights, motors, amplifier racks (power distribution racks and dimmer racks), video projectors, and more.
To insert a feeder cable:
  1. Click the tool and mode.
  2. Click to place the start of the cable, and draw the cable polyline, clicking at each vertex. Double-click to finish drawing the cable.
The first time you use the tool in a file, a properties dialog box opens. Set the default properties.
After placement, the cable path can be adjusted with the Reshape tool. The properties can be edited from the Object Info palette.
Inserting Multicables
Marking Cable Measurements
Selecting, Refreshing, and Converting Cables
Creating Cable Worksheets
Setting Preferences
Associating Load Objects with a Hanging Position
Numbering Light Plot Objects
