Spot00015.pngInserting Jumper Cables
Mode
Tool
Tool set
Modes for the Polyline Tool
Jumper Cable
Lighting
These break out cables connect the multicable to the devices, breaking out the power into individual circuits. Single circuit cables also go from the rack or the break out cable to the device.
Jumper cables can be automatically added to the drawing; see Creating a Jumper Cable Chain.
To insert a jumper cable:
  1. Click the tool and mode.
  2. Click to place the start of the cable, and draw the cable polyline, clicking at each vertex. Double-click to finish drawing the cable.
The first time you use the tool in a file, a properties dialog box opens. Set the default properties.
After placement, the cable path can be adjusted with the Reshape tool. The properties can be edited from the Object Info palette.
Inserting Data Cables
Creating Cable Chains
Marking Cable Measurements
Selecting, Refreshing, and Converting Cables
Creating Cable Worksheets
Setting Preferences
Associating Load Objects with a Hanging Position
Numbering Light Plot Objects
