Connect00031.pngPlacing distribution amplifiers
Tool
Tool set
Distribution Amplifier
Schematics
The tool places audio or video distribution amplifiers.
Mode
Description
Single Click
Places a single distribution amplifier at the click location
Linear Array
Places an array of distribution amplifiers along the drawn line
Video Distribution Amplifier
Inserts a video type of distribution amplifier
Audio Distribution Amplifier
Inserts an audio type of distribution amplifier
Make and Model
Select the make and model from the list
Distribution Amplifier Number
Select the starting number
Number of Outputs
Select the number of outputs
To insert a distribution amplifier:
1.      Click the tool, and select either audio or video mode.
2.From the Tool bar, select the make and model, starting number, and number of outputs (up to the maximum for the selected model).
If you continue placing the same distribution amplifier, the number automatically increments.
3.Click to place the distribution amplifier into the drawing. If placing the device into an existing circuit, the device splits the circuit.
●       In Single Click mode, click once to place the object.
●       In Linear Array mode, click once to start the array; move the cursor to set the distance and direction of the linear array. Press the Shift key to constrain to the horizontal or vertical direction. The preview indicates the spacing and placement of the objects; the floating Data bar shows the Count. Click to place them.
The device can be edited later from the Object Info palette.
Concept: Specialized device type and prefix
Placing devices
Building a device
Adding sockets, loops, and terminators
Editing devices and sockets
ConnectCAD
