Schematic
view propertiesThe properties of schematic rigging and load objects can be edited from the Object Info palette. When a schematic object is selected, the Object Info palette displays “<Object Name> in Schematic View.” When multiple schematic objects are selected, the number of “Schematic View Objects” displays instead.
The properties of the parent objects can also be viewed and edited from the schematic properties. When the parent objects are edited, the schematic instances may need to be updated; see Updating schematic views.
When multiple schematic objects are selected, you can edit them (or their parent objects) individually by enabling Individual Edit mode on the Object Info palette; see Editing multiple objects.
Click
to show/hide the parameters.
