Stair
settings: General tabThe stair configuration is set on the General tab. If you switch to another stair configuration after making parameter changes on any tab, the New Stair dialog box opens.
Switching to a new configuration loses any parameter settings that have already been made. The settings from the current stair configuration can be transferred to the new stair if needed. Select specific settings to transfer, or click All or None to select or deselect all the settings.
To set the stair configuration:
Click the General tab.
Click
to show/hide the parameters.
