Palette display options
You can set up the display of palettes, and individual tabs in multiple-tab palettes, to make the most of your working space and keep the elements and tools you use most where you want them.
●       Most palettes/tabs can be resized by the standard Windows or Mac resize method.
●       The visibility of palettes, and of individual tabs on multiple-tab palettes, can be toggled on and off (see Controlling the visibility of palettes and tabs).
●       Individual tabs can be detached from multiple-tab palettes and positioned as needed, or their order can be resequenced within the palette (see Detaching and returning palette tabs).
●       Palettes and detached tabs can be minimized while not in use (see Minimizing palettes).
●       Palettes and tabs can be docked to the application window (see Docking palettes).
●       Tool palettes have a special set of features, as described in Tool palette features.
Each time you exit the Vectorworks program, the current palette settings and positions are automatically saved for each workspace in a file in your user folder ([User]\Settings\SavedSettings.xml). The settings in this user file override the initial palette settings in the workspace file. To reset to the original workspace settings, click Reset Saved Settings from the Vectorworks preferences: Session pane.
Palettes and tool sets
Minimizing palettes
Docking palettes
Saving palette positions and settings
Application window
