Detail
callout instancesDetail callout instances associated with a detail viewport can be added to or deleted from design layers or viewport annotations. In addition, the Detail Callout Instances dialog box provides an easy way to navigate from a detail viewport to its associated detail callouts.
To edit detail callout instances or navigate to a detail callout:
1. Select the detail viewport whose detail callout you want to navigate to or edit.
2.Click Detail Callout Instances from the Object Info palette.
The Detail Callout Instances dialog box opens.
Click
to show/hide the parameters.
