Spot04087.pngTruss properties
Many of the truss parameters can be edited from the Object Info palette; other truss parameters must be edited from the Truss Properties dialog box; see Setting custom truss parameters.
Parameter
Description
Orientation parameters
To orient the truss, Vectorworks applies the Roll, Hanging Angle, and Rotation settings in the this order
Roll
Rotates the truss object on its X axis; the truss rotates around its insertion point
Hanging Angle
Rotates the truss object on its Y axis; the truss rotates around its insertion point
Rotation
Rotates the truss object on its Z axis; the truss rotates around its insertion point
Properties
Symbol
Displays the truss symbol
Type
Displays the truss type, manufacturer, or catalog identification number
Name
Identifies the truss section; if the truss is converted to a hanging position, the name of the hanging position displays automatically
ID
Unique identifier for truss calculations and labels; if blank, a value is automatically assigned when calculations are run (Braceworks required)
Position Name
Enter a name for identification and reporting purposes. When the truss is used as a hanging position, this name automatically populates the Position field of any attached load objects.
Height/Width
Displays the height and width values of the truss
Total Weight
Sets the total gross weight of the truss; corner trusses are considered as point loads in calculations, while all other truss types are considered as distributed loads
Distributed Weight
Displays the weight per unit of length for the truss
Length
(straight or curved truss only)
Displays the length of the truss
Hinge Angle
(hinge truss only)
Sets the angle between the hinge parts.
You can manually adjust the hinge angle by moving the control points on the hinge truss.
Insert Locking Pipe
(book hinge only)
Inserts a lighting pipe to connect and lock the hinge parts.
The lighting pipe is considered as a separate object in Braceworks calculations.
Cross Section
Displays the cross section unique ID number, when a cross section file has been associated with the truss as described in Specifying cross section data
Cross section information is required for valid calculations; if there is no identified cross section, calculations will not be complete.
Connectable with
Displays the ID of rigging objects that can be connected to this truss in Auto Connect mode, forming a structural system
Truss System
Displays the name of the truss system to which the truss belongs, along with the truss line number
Display
Draw 3D Only
Hides the 2D-only portion of the object, making it easier to view and rotate in 3D views
Center line
In Top/Plan view, displays the truss center line; some load objects are attached at the truss center line
Actions
See Modifying trusses and systems for parameter descriptions
Creating a custom truss symbol
Modifying truss symbol data
Connecting rigging objects
Changing the trim height of a system
Replacing trusses
Concept: Rigging objects
Adding loads
Concept: Creating a connected rigging system
