Spot03817.pngLighting device properties
Lighting device parameters can be viewed and edited from the Object Info palette. Select the parameters you want to display from the Spotlight preferences: Lighting Devices: Parameters pane. This pane also controls which parameters can be set independently for accessories and for the cells in multi-cell devices.
If your file was created in a previous version of Vectorworks, any default lighting device parameters that were removed from the current version can still be accessed on the Spotlight preferences: Lighting Devices: Parameters pane. You can display these parameters on the Object Info palette or remove them from the file. Any customized lighting device parameters maintain their custom values but update their default values to match the current version.
To display the cell parameters from a multi-cell lighting device, select the desired cell in the Edit Cell field.
To display the accessory parameters from the associated lighting device or cell, select the desired accessory in the Edit Accessory field. When a value other than <None> is selected, the parameters of the specified accessory or accessories are shown, instead of the lighting device parameters. The Device Type field indicates whether an accessory or lighting device is being edited.
The parameters below are described in terms of lighting devices, but the same behavior applies to accessories unless otherwise noted.
Lighting device parameters can also be edited from the Lighting Device dialog box; see Cómo cambiar las propiedades de luminaria. Change advanced light properties, including turning the associated light source on, by editing the light source embedded within the device; see Propiedades de luz avanzadas.
DMX patching may change the lighting device (and accessory) parameters as conflicts are resolved; see Conexiones DMX .
For a custom lighting device symbol without an information record attached, enter the required parameters (see Attaching the Light Info Record). An entry is not required for every field.
Parameter
Description
XYZ/IJK Location/Rotation
Changes the lighting device’s location and rotation; the labels rotate with the lighting device unless Right-Reading is selected in the Label Legend Manager (see Formatting the label legend layout). In a 3D view, if a lighting device is focused, the lighting device rotates automatically to point at the focus.
A lighting device and its accessories move and rotate together. For this reason, the position and orientation of an accessory relative to its associated lighting device cannot be changed from the lighting device Object Info palette. To adjust the accessory position in 2D and 3D views, use Modo editar accesorio instead.
Edit
Opens the Lighting Device dialog box, to edit the parameters of one or more lighting devices; see Cómo cambiar las propiedades de luminaria
Edit Accessories
Opens the accessory edit mode, to edit accessories in 2D and 3D views; see Modo editar accesorio
Device Type
Displays the type of object that is selected. Normally, lighting device are Light device types (Moving Light, Device, Practical, SFX, Power, and Other are also considered Light types). Accessories such as color frames, barn doors, and top hats are Static Accessory types. Accessories that require a control channel, such as color scrollers, are Accessory types.
Instrument Type
Displays the specific type of lighting device
Edit Cell
(multi-cell lighting devices only)
Select which cell displays its parameters, or select <All> to display the parameters of all cells in the device. <Multiple values> displays for parameters that are not identical for all cells.
The cells are listed by their index number - color - channel.
Edit Accessory
(accessories required)
Choose whether the Object Info palette displays the lighting device or accessory parameters, and select which accessories display their parameters. The Device Type indicates whether lighting device or accessory parameters are being edited.
For multi-cell lighting devices, the options depend on the Edit Cell selection. If all cells are selected, all or none of the device’s accessories can be edited. If a single cell is selected, the accessories specific to that cell can be edited.
<None>: Displays the parameters of the lighting device, not its accessories.
<All>: Displays the parameters of all the attached accessories. <Multiple values> displays for parameters that are not identical for all accessories.
Accessory: Displays the parameters of the specified accessory. The accessories are listed by their index number - accessory symbol name.
Fixture Mode
Specifies the Vision fixture mode of the lighting device, for export to the Vision program. The DMX Footprint is set automatically by the selected mode and cannot be edited; however, if a GDTF Fixture Mode is specified too, this mode will set the DMX Footprint instead.
For custom or generic lighting devices, select Other, and select a suitable mode from the Vision Fixture Mode dialog box. See Selecting a fixture mode.
GDTF Fixture
Specifies the GDTF fixture mode of the lighting device, for export to a lighting console or visualizer. The DMX Footprint is set automatically by the selected mode and cannot be edited.
For custom or generic lighting devices, select Other, and select a suitable mode from the GDTF Fixture Mode dialog box. See Selecting a fixture mode.
After you select a GDTF fixture mode, this parameter displays the GDTF fixture name.
See Workflow: Visualizer data exchange for information about .gdtf files.
GDTF Fixture Mode
Displays the selected GDTF fixture mode
Edit GDTF Data
Opens the GDTF Fixture Builder, for editing GDTF data directly in Vectorworks. See Edición de datos en formato GDTF.
Wattage
Indicates the power consumed by the lighting device
Purpose
Specifies the purpose of the lighting device
Position
Displays the name of the associated rigging object, if the lighting device is attached. Optionally, attach this object to a rigging object, or change the rigging object association, by entering the Position Name of the rigging object. Delete the name to break the association.
For other methods to attach loads, see Making the attachment.
Unit Number
Identifies the lighting device location on the hanging position or rigging object
Color
Specifies the gel color number according to manufacturer code, RGB values, color name from the file, or web (hex) codes; when the light associated with the lighting device is turned on, Color specifies the actual light color. Use + between color numbers to indicate combinations of two or more colors. See Lighting device color.
The color setting can affect the display of the lighting device color, depending on the Spotlight preferences; see Spotlight preferences: Lighting Devices: Classes and Color pane.
Dimmer
Specifies the dimmer number of the lighting device
Absolute Address
Specifies the address of the lighting device without a universe indicator; for example, universe 2/address 1 is absolute address 513.
To unpatch the lighting device, set this value to 0 (zero) to remove the universe, address, and DMX address information, or unpatch the lighting device from the Patch dialog box; see Conexiones DMX .
In files created prior to version 2020, this field may also display as User Address to ensure compatibility.
Channel
Specifies the channel number, or channel “name,” of the lighting device.
This name identifies the device when power patching; see Power patching the electrical system.
Universe/Address
Specifies the universe and address, separated by a front slash separator; the separator can be changed as described in Spotlight preferences: Lighting Devices: Parameters pane
Universe
Specifies the universe assigned to the lighting device; see Spotlight preferences: Universes pane
DMX Address
Specifies the DMX address assigned to the lighting device; see Spotlight preferences: Universes pane.
In files created prior to version 2020, this field may also display as User U Address to ensure compatibility.
DMX Footprint
Displays the number of control channels used by the lighting device. If the lighting device has a specified Fixture Mode or GDTF Fixture Mode, the number of channels is automatically assigned.
If fixture modes are specified for both Vision and GDTF, the GDTF mode sets the number of channels.
Circuit Number
Indicates the circuit number where the lighting device is plugged in
Circuit Name
Specifies the name of bundled circuit group
System
Specifies the letter describing the control system (Lightwright-compatible parameter)
User Field 1–6
Provides user-defined fields; use these extra fields to keep track of any desired data (see Spotlight preferences: Lighting Devices: Parameters pane)
Voltage
Specifies the voltage of the lighting device
Breaker ID
Provides the power distribution identifier of the lighting device
Time
Approximates the time required to work with the device, useful in reports
Cost
Specifies the rental cost of the device, useful in reports
Frame Size
Indicates the dimensions of the color cut
Field Angle
Sets the vertical field angle of the lighting device’s light beam
Field Angle 2
Sets the horizontal field angle of the lighting device’s light beam
Beam Angle
Sets the vertical beam angle of the lighting device’s light beam
Beam Angle 2
Sets the horizontal beam angle of the lighting device’s light beam
Weight
Specifies the lighting device weight.
For lighting devices with accessories, use the Edit Accessory field to select each accessory and then specify its weight. The weight of the lighting device and all accessories is combined to calculate the Total Weight of the lighting device.
Gobo 1
Indicates the gobo texture number for the first gobo.
Specifying the gobo texture by clicking Edit in the Object Info palette provides a graphical method of selecting gobo textures.
Gobo 1 Rotation
Sets the rotation angle of gobo texture 1
Gobo 2
Indicates the gobo texture number for the second gobo
Gobo 2 Rotation
Sets the rotation angle of gobo texture 2
Gobo Shift
Adjusts the position of the lighting device gobos to the front or rear
Mark
Provides a user-defined label (Lightwright-compatible parameter)
Draw beam
Draws an accurate wireframe representation of the light beam; the light beam is drawn based on the lighting device parameters, and can be used to check whether the stage and focus areas have been adequately lit (see Trazado de representaciones de rayos de luz). Spotlight preferences setup can globally specify the appearance and display of the elements in the light beam (angles and centerline).
Draw beam as 3D solid
Generates a light beam that appears solid when rendered
Use vertical beam
By default, draws the wireframe beam in a vertical orientation when possible, when either Draw beam or Draw beam as 3D solid is selected. When deselected, the beam is usually drawn in a horizontal orientation.
Show Beam at
In a 2D view, select whether to draw the beam as it crosses the focus, at the falloff distance as projected through the focus, or in both areas
Replace Lighting Device/Replace Accessory
Opens the Resource Selector; double-click a resource to select it.
Replace Accessory displays when the selected lighting devices include one or more accessories.
Select the accessory or accessories to replace from the Edit Accessory list.
If <All> accessories are selected for editing, all the accessories on the selected device(s) are replaced by the chosen resource.
If a specific accessory is selected for editing, only that accessory is replaced.
If one of the selected lighting devices is a multi-cell, you can only replace the accessories on the cell(s) specified in the Edit Cell field.
Refresh Labels
Refreshes lighting device label contents if parameter changes have been made, or 3D label positions if the view has changed
Falloff Distance
Specifies how far the wireframe light beam is drawn beyond the focus
Lamp Rotation Angle
Indicates the rotation angle of the virtual elliptical light source, from 0 to 90°
Shutter parameters
Controls the angle and depth of top, left, right, and bottom shutter cuts. Each shutter is located at 90º intervals around the lighting device, and can be adjusted +/- 45º. The shutter depth ranges from 0 to 100%, with 100% cutting through the center of the light source.
Symbol Name
Displays the name of the symbol used to create the lighting device or accessory
Use GDTF Geometry
When a valid GDTF mode is selected, replaces Vectorworks symbol geometry with the geometry specified in the GDTF resource.
This mode is enabled by default when you import a .mvr file that creates a new lighting device from a GDTF resource.
Use Legend
Select the label legend to apply from the list of label legends in the file (see Label Legend Manager)
3D Legend View
When the label legend includes 3D labels, select the view for the labels when displaying the drawing in a 3D view.
Select Screen Aligned to always view the labels aligned with the screen plane (in a viewport, screen aligned labels match the view)
After changing the view, click Refresh Labels to obtain the selected legend view, or select the Refresh Lighting Devices command.
Easily copy the label legend positions to selected lighting devices by Cómo cambiar las propiedades de leyenda de rótulo de una selección.
Flip top and bottom 3D legend
Mirrors the 3D label along the X axis of the lighting device (for example, a label legend that displays at the top of the device displays on the bottom instead)
Flip left and right 3D legend
Mirrors the 3D label along the Y axis of the lighting device (for example, a label legend that displays to the right of the lighting device displays on the left instead)
Rotate 3D legend with Z rotation
Matches the 3D label legend views with the lighting device’s rotation
Flip front and back 2D legend
Mirrors the label legend along the X axis of the lighting device (a label legend that displays in front of the lighting device displays behind it instead)
Flip left and right 2D legend
Mirrors the label legend along the Y axis of the lighting device (a label legend that displays to the right of the lighting device displays on the left instead)
Focus
Names the focus point object assigned to the lighting device. The focus point must be defined first (see Creación de objetos de punto focal ).
If the Pan and Tilt values are adjusted later, the lighting device loses its association with the focus point.
Pan
Controls the lateral rotation angle of the lighting device. If a focus point is assigned, this value automatically updates.
Tilt
Controls the vertical rotation angle of the lighting device. If a focus point is assigned, this value automatically updates.
Throw Distance
Controls the distance from the lighting device to its focus location. If a focus point is assigned, this value automatically updates.
Custom plan rotation
Select this option to specify a rotation angle for Top/Plan view that is independent from the device’s Rotation parameter. When this option is selected, specify the Plan Rotation angle.
Vertical Focus Angle
Displays the focus angle up from vertical
Horizontal Focus Angle
Displays the focus angle down from horizontal
Angle To Face
Displays the angle at which the light hits the face plane of the lit subject at the focus
Off Axis Angle
Displays the angle from the centerline of the focus to the lighting device. The bottom of the focus is the centerline; if a focus point is used, move the focus point to change the centerline location.
Load Information
A lighting device is considered a point load in Braceworks calculations; if the insertion point is on a structural element, it is considered to be a load on that structure. Load information is used for Braceworks calculations and reports (Braceworks required).
Include in calculations
Includes the lighting device in Braceworks calculations; deselect to exclude the device from participating in structural calculations
Load Group Name
The load category is always Light for lighting devices
Load ID
Enter a unique ID for the load for informational use in reports
Load Name
Identifies the object in load calculations; normally the object name is used
Total Weight
Enter the total weight of the object.
For lighting devices with accessories, this parameter displays the total weight of the device and its accessories and it cannot be edited.
Power Information
A lighting device can be power patched within the electrical system; see Power patching from the Object Info palette. Power information is used for power calculations and reports.
Select Range
The socket connection parameters are displayed in sets of seven. Select which set of sockets to display for editing. The sets are numbered according to the input stacking order.
Power In
Select the socket for the input connection
Consumption
Displays the amount of power required by the device
Voltage
Displays the lighting device voltage
Connector
Displays the connector used for the input connection
Edición de luminarias
Cómo cambiar la leyenda de rótulo
Conexiones DMX
Visualizer data mapping
Exporting Vectorworks Spotlight data
