Design SuiteEditing elevation
Mode
Tool
Workspace: Tool set
Edit Elevation
Grade
Architect and Spotlight: Building Shell
Landmark: Site Planning and Dims/Notes
If the elevation changes after one or more grade objects have been placed, there is no need to replace the existing grade objects. Change the elevation of one end of a grade object, or offset the elevation of selected (or all) grade objects in the drawing.
Elevation marker symbols must be at a valid scale to edit elevations. If the Edit Elevation dialog box does not open, increase the marker scale factor for the grade object.
To edit grade object elevation:
Click the tool and mode.
Click at the start or end of a grade object.
On the Edit Elevation dialog box, edit the grade.
Parameter
Description
Elevation at Selected End Marker
Changes the elevation for the selected end of the grade object
Offset Selected Grade Objects
Adjusts the elevation of all selected grade objects by the specified amount
Offset All Grade Objects
Adjusts the elevation of all grade objects in the file by the specified amount
Calculating and displaying grade and elevation
Specifying global grade object preferences
Inserting grade objects
Analyzing grade
Creating loci from a grade object
