Design SuiteCreating countertops
Tool
Tool set
Countertop
Countertop tool
Design Suite, Architect, Spotlight: Furn/Fixtures
Landmark: Building Shell
Use the Countertop tool to create a countertop that can be customized for greater detail and reporting. Features can include backsplashes, inserts, and custom edges, including waterfall edges.
Countertop Example
Countertops can be drawn manually using Vertex mode or based on selected cabinet geometry using Marquee mode or Pick mode. Bridge mode creates a countertop that spans open areas between selected cabinets, such as to accommodate appliances or a seating area. Corner cabinets are also taken into account and different depths are supported.
The countertop, backsplash, trim, and edges can have different materials and textures applied, to create a detailed finish. Holes can also be created in the countertop by clipping the surface or by inserting symbols, such as sinks, into the countertop. See Drawing countertops and Editing countertops for additional information. Once countertops have been created, reports can be made for the size, area, and volume, and data visualization can be used to create a cutting plan with edge treatments and holes. See Creating a new data visualization.
Mode
Description
Check mark
Check Mark mode
Executes the Marquee mode or Pick mode operation.
Vertex
Vertex mode
Draws a countertop using the selected polyline creation options and the current preference settings
Marquee
Marquee mode
Creates a rectangular marquee box around cabinets to select those that define the countertop shape
Pick
Pick mode
Individually selects the cabinets that define the countertop shape
Bridge
Bridge mode
For Marquee mode and Pick mode, creates a countertop that bridges open spaces between selected cabinets
Polyline creation options
For Vertex mode, selects the method for drawing the polyline upon which the countertop is based; see Creating polylines
Countertop Style
Opens the Resource Selector to select a countertop style for placement; double-click a resource to activate it
Preferences
Preferences
Opens the Countertop Preferences dialog box, to set default countertop parameters; see Countertop settings
Drawing countertops
Countertop settings
Editing countertops
