Resource Manager: Resource viewer pane
Resource type
The resource viewer pane displays resources in the file selected in the file browser pane. Select a specific type of resource from the tool bar to filter the display, or select the option to show all resources. Folders always display at the top of the pane. To change the sort order, right-click and select Sort By from the context menu. You can always sort by name, in ascending or descending order; when all resources are displayed, you can also sort the resources by type.
Resource views
Three buttons on the palette tool bar control the display of resources in the resource viewer pane.
Resource view buttons left to right: Thumbnails View, List View, Thumbnails List View
All views show the name of the resource and a preview image or representational icon for each resource. Symbol definitions display in the color associated with their type (see Concept: Vectorworks symbols). Page-based hatches, tiles, and line types also display in green.
Resources that have various levels of detail always display the preview using the medium level of detail setting. Therefore, if a resource only has a high or low level of detail representation, its preview appears blank.
For plug-in objects with associated manufacturer catalogs, individual catalog items cannot be selected using the Resource Manager; see Concept: Plug-in object styles and catalog items.
Sample views left to right: Thumbnails View, List View, Thumbnails List View
To change the view, click a view button on the palette tool bar. Alternatively, right-click anywhere in the resource viewer pane, and select View As from the context menu. When all resources are displayed, you can click the Name or Type column header in List view to resort the list alphabetically.
Resource viewer menus
The context menus in the resource viewer pane provide commands to work with the folders and resources that display in the pane. Right-click on the desired folder or resource; the context menu lists commands that apply to that item.
Available commands are determined by the type of resource selected, as well as what file the resource is in. For example, commands that modify the resource (such as Edit and Rename) are only available in the active file.
Click to show/hide the commands.Click to show/hide the commands.
Command
Description
Shortcut key equivalent
Add a Tag
Opens the Add a Tag dialog box; enter a tag to help you locate the resource with the search function. See Adding and editing resource tags.
None
Apply
Applies the selected resource to the selected drawing object
Double-click
Assign Classifications
For a material resource or black symbol, opens the Assign Classifications dialog box, where you can click Look up to select a classification standard and reference ID. See Looking up classification standard IDs.
None
Attach Record
Opens the Attach Record dialog box to attach a record to the symbol definition (changing all symbol instances, existing and future). See Attaching record formats to a symbol definition.
Not applicable
Break Reference
When a referenced resource is selected, breaks the link between the current file and the master file; the resource remains in the current file but is no longer referenced
None
Create Texture from Hatch
Creates an associated texture from an existing hatch; see Creating a texture from a hatch
Ctrl-double-click (Windows)
Option-double-click (Mac)
Delete
Deletes the selected resource from the file. When a folder is selected, deletes the folder and all resources in the folder. See Deleting or replacing resources.
Delete key
Duplicate
Opens the Assign Name dialog box; enter a name to create a duplicate of the selected resource
None
Edit
Opens an edit dialog box for the selected resource.
If the resource is referenced, an alert prompts you to verify that you want to edit the resource before the edit dialog box opens. Edits made in the current file are also saved automatically to the source file, which may affect references to this resource in other files.
Edit 2D Components
Edits the 2D component of the symbol definition; see Creating 2D components for symbol definitions and plug-in objects
Edit 3D Component
Edits the 3D component of the symbol definition; see Editing symbol definitions
Edit Hole Component
Edits the hole component of the symbol definition; see Adding a hole component to a symbol definition
Edit Definition
(Landmark required)
Edits the definition of the plant symbol as described in Creating plant styles
Edit Image Attributes
Opens the Image Attributes dialog box, to edit the attributes of the imported image as described in Mapping image fills
None
Edit Image Effects
Opens the Image Effects dialog box, to apply Image effects to the imported image
 None
Edit Symbol Options
Opens the Symbol Options dialog box, to edit symbol definition parameters; see Editing symbol definitions
Edit Tags
Opens the Edit Tags dialog box to add, edit, or delete tags associated with the resource; see Adding and editing resource tags
None
Enter
Opens the selected symbol folder or script palette to display the symbols or scripts inside
Double-click
Export
(Design Suite product required)
Opens the Export Resource dialog box to export the selected resource to another file. When a folder is selected, exports the folder and all resources in the folder. See Exporting resources.
None
Extract Image(s)
Opens the Select Folder (Mac) or Export Image File (Windows) dialog box to save a .png file extracted from the selected image-based resource.
To extract images from all image-based resources in the current file execute this command with no resources selected. Select a resource folder to extract images from all image-based resources in the folder.
None
IFC Data
Attaches IFC data to the selected symbol definition, changing all symbol instances, existing and future. See Assigning IFC data to objects.
None
Import
When a resource from a different file is selected, imports the resource into the active file
None
Make Active
Makes the selected symbol or plug-in active, and activates the Symbol Insertion tool so that the symbol or plug-in can be inserted into the drawing
Double-click
Move
Opens the Move [resource] dialog box to move the selected resource to another folder
Not applicable
New [resource type] in Active Document
Opens a dialog box to create a new resource in the active file, of the same type as the resource selected; see Creating resources
None
New [resource type] in [selected file]
Opens a dialog box to create a new resource in the selected file, of the same type as the resource selected; see Creating resources
None
New Folder in Active Document
When viewing a specific resource type, creates a new resource folder, of the type being viewed, in the active file
None
New Folder in [selected file]
When viewing a specific resource type, creates a new resource folder, of the type being viewed, in the selected file
None
Open
When a worksheet is selected, opens the worksheet on screen for edits; when a script palette is selected, opens the palette
Reference
When a resource from a different file is selected, creates a reference to it in the active file; see Referencing resources
None
Rename
Opens the Assign Name dialog box; enter a name to rename the selected resource.
If the resource is referenced, an alert prompts you to verify that you want to rename the resource before the Assign Name dialog box opens. The name change made in the current file is also saved automatically to the source file, which may break references to this resource in other files. Referenced symbols, gradients, record formats, hatches, tiles, Renderworks backgrounds, textures, sketch styles, wall styles, text styles, slab styles, plants, and image resources can be renamed.
(Image fills only)
Run
Runs the selected script. Text documents that contain scripts must be run using the Tools > Plug-ins > Run Script command.
Double-click
Select Resource Location
After a search, selects the file that contains the selected resource in the file browser pane
None
Set Thumbnail View
For the thumbnail preview, adjusts the view of the selected symbol(s)/plug-in object style(s).
If a folder is selected, the view is applied to all symbols/styles within the folder.
None
Set Thumbnail Component
For the thumbnail preview, adjusts the component view of the selected symbol(s)/plug-in object style(s); the options available depend on the thumbnail view selection.
None
Set Thumbnail Render Mode
For the thumbnail preview, adjusts the render mode of the selected symbol(s)/plug-in object style(s).
None
Set High-Res Preview View
In the preview pane, adjusts the view of the selected symbol(s)/plug-in object style(s).
None
Set High-Res Preview Component
In the preview pane, adjusts the component view of the selected symbol(s)/plug-in object style(s); the options available depend on the preview view selection.
None
Set High-Res Preview Render Mode
In the preview pane, adjusts the render mode of the selected symbol(s)/plug-in object style(s).
None
Sort By
Sorts the resources by name (when all resources are displayed) or type, in ascending or descending order
None
View As
Changes the view mode in the resource viewer pane; see Resource views
None
Worksheet On Drawing
Places the selected worksheet on the drawing for display and printing
Double-click
Searching for a resource
Using resources in your drawing
