Design SuiteWindow settings
These settings are available in the following locations:
Window Preferences dialog box (creating an object)
Window Settings dialog box (editing an object)
Object Info palette (editing an object)
Window Style dialog box (creating or editing a style)
If a style is selected, only parameters set by instance can be edited (see Concept: Plug-in object styles). Parameters available only on the Object Info palette are listed at the bottom of the page.
You can create plug-in objects with a combination of parameters that are determined by the manufacturer’s catalog item, by style and/or by instance, and then optionally save them as a plug-in object style. Catalog parameters have a fixed value established by the manufacturer and cannot be edited by the user. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing (see Concept: Plug-in object styles).
Additional plug-in object settings for the class, the 2D component and cut plane display, and wall insertion options are available; see Additional plug-in object style and instance options.
Window settings: Overall
Parameter
Description
Use Style
From the Resource Selector, double-click a resource to activate it, or click Unstyled. If a styled object is converted to unstyled, the current values are retained, but all parameters are set to By Instance to allow editing.
By Style/Instance/Catalog
A graphic indicates whether each parameter within the style is set to By Catalog and defined by the catalog item, set to By Style and given a fixed value by the user, or set to By Instance and editable in the dialog box. An object style may have a combination of all three of these settings, to balance the need for consistency and flexibility.
By Style/Instance/Catalog settings are established by the style and cannot be changed from the settings dialog box.
To edit the object style, see Editing plug-in object styles; editing the style modifies all plug-in objects in the file that use the style.
Select from Catalog
If the catalog item is set by instance, opens the Catalog dialog box for selecting catalog items for plug-in object styles (see Selecting catalog items for plug-in object styles). If a current catalog item is associated with the style, static text displays the item’s description.
The catalog item itself can be set to By Style (to ensure that all objects using that style use the same catalog item) or to By Instance (if, for example, different sizes of the otherwise identical object require different catalog items).
3D Preview
Dynamically displays a 3D preview of the window with the currently selected parameters; the window's exterior side faces the Front view
View
Select the standard view for the 3D preview of the window
Render
Select the render mode for the 3D preview of the window
Detail
Select the detail level for the 3D preview of the window
Top/Plan Preview
Dynamically displays a Top/Plan preview of the window with the currently selected parameters; the window's exterior side is toward the bottom
Detail
Select the detail level for the Top/Plan preview of the window
Window settings: General pane
Parameter
Description
Window Shape
Select the window shape.
All window shapes other than rectangular are fixed glass; only the appropriate parameters on each pane of the Window Settings dialog box are available for these fixed glass shapes.
Top Shape
Select the shape of the top of the window as viewed from the exterior side
Include transom
Adds a transom above the window; transom parameters are set from the Transom pane
Rise
When applicable for the selected Top Shape, enter the distance between the start of the top shape to the top of the window
Spring
Enter the distance traveled above the bottom pane before the top shape starts; if Square is selected as the Top Shape, the spring is the total height
Use symbol geometry
Select Use symbol geometry. From the Resource Selector, double-click a symbol to apply it.
The symbol name displays and the preview is updated with the selected symbol.
When a symbol is selected, all fields pertaining to the window’s geometry are overridden by the symbol geometry; however, parametric values are still available for scheduling and reporting purposes only.
Size Reference
Select the appropriate option to define the window width and height; the Size Reference selection automatically updates the Width and Height fields, but does not change the size of the window:
Sash Opening: this represents the window opening including the sash and glass, but excluding the transom and frame; this is typically used to show the window opening for emergency exit purposes.
Unit Size: this represents the current overall window width and height, including the transom and sash; this is the default setting for imperial units.
Rough Opening: this represents the current overall window width and height, including the transom, sash, and shim gap (for the Opening Configuration, the Size Reference is automatically changed to Rough Opening); this is the default setting for metric units.
Width/Height
The width/height of the window is measured based on the Size Reference selection:
Sash Opening: width/height is measured at the outside of the sash.
Unit Size: width/height is measured at the outside of the frame.
Rough Opening: width/height measures the rough opening.
For circle, half circle, hexagon, and octagon shaped windows, the height parameter is disabled, and the parameter is automatically calculated based on the window’s width.
Elevation in Wall
Enter the window elevation
Elevation Reference
Select either the sill or the head of the window as the elevation reference point
Insertion Relative to
Specify whether the insertion point is relative to the exterior face, center, or interior of the frame.
Additional wall insertion options are available, as described in Additional plug-in object style and instance options.
Unit Offset Reference
When the unit is inserted into an assembly, displays the assembly's unit offset reference
Unit Offset
Enter the unit's offset relative to the unit offset reference location. A positive value offsets the window toward the exterior and a negative value offsets toward the interior.
Curtain wall window
Indicates that the window will be placed in a curtain wall, where its width and height are based on the surrounding panel size and the bottom frame where it is placed. A curtain wall window does not have as many available parameter options as a standard window. Configurations are limited to those that apply to curtain wall placement.
Create niche for space objects
Creates niche geometry that space objects can include in their net boundary areas; see Space settings: 2D Boundaries and Area pane
Interior Side
Select which side of the wall the window considers the interior side, for the purpose of defining handing- and location-related settings such as sash, sill, hinge, and trim location and open direction. This relates to the window settings only and does not change the wall's direction; see Wall direction.
Configuration
Select the window type. Depending on the selection, a variety of window settings are enabled or disabled automatically, as described in the following sections.
To create a simple opening in a wall for defining a window break without creating any geometry to represent the window, select the Opening option. To define a custom window configuration, select Custom Configuration and click Custom Configuration Options to open the Custom Configuration Options dialog box (see Creating a custom window opening configuration).
Operation
For Configurations that provide options, select the advanced operation. For the Sliding Configuration, "O" represents a fixed sash and "X" represents an operating sash.
For sliding windows set to Picture Window Slider Operation, Unequal sash is selected in the Sash pane and the Custom Configuration Options dialog box.
Additional parameters
The available parameters related to sashes, hinge sides, locations, and open/swing directions depend on the selected Configuration and Operation. For parameters with left/right settings, those directions are as viewed from the exterior side.
Many of these parameters, along with Interior Side can be changed interactively in the drawing area; see Interactive handing of doors and windows.
Sash Size
Displays the width and height of each sash, calculated from size parameters
Window settings: 2D Visualization pane
Parameter
Description
Attributes list
Sets the Top/Plan visibility and attributes for the window parts. Select one or more rows, and click the applicable columns to select the desired settings.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Window Class> to place the attributes in the same class as the window object.
Set custom pen and fill attributes, or select an option to control them by object (from the Attributes palette), by class, by material (where applicable), or select None.
Operation Direction Marker
Select the direction marker style to use when the operation direction is visible, or set it by class. Click Custom to add a custom marker style or Edit Marker List to edit the list of options; see Marker attributes.
Window settings: 3D Visualization pane
To set materials and classes for window parts, see the Materials and Classes pane, below. 3D Visualization options are not enabled for the Opening Configuration.
Parameter
Description
3D Hinge Direction Marker
Show interior/exterior marker
Draws lines representing the hinge direction of the window sashes on the interior/exterior side of the window in 3D
Use hinge marker class attributes
Sets the hinge direction marker’s attributes by class
Hinge Direction Marker Class
To control visibility and, if Use hinge marker class attributes is selected, appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Window Class> to place the hinge marker in the same class as the window object.
Marker Points Towards
Set the hinge direction marker to point toward the hinge or toward the handle
Show 3D open
Draws 3D window sashes as open at the specified Open Angle
Clerestory
Draws the window as dashed in Top/Plan views if the sill is higher than the specified elevation and draws the window as non-breaking (solid) if the sill is below the specified Cut-plane Elevation.
For correct clerestory display in horizontal section viewports, whether above, below, or cut by the viewport’s cut plane, the window object automatically creates 2D components for the Top and Top and Bottom Cut views (see Creating 2D components for symbol definitions and plug-in objects). If the Top/Plan Clerestory setting is set By Style, the instance will override it for horizontal section viewports.
Cut-plane Elevation
Enter the cut plane elevation for Top/Plan views
Window settings: Detail Levels pane
Vectorworks can automatically display the desired detail level based on the design layer’s scale; see Document preferences: Display tab. Different levels of detail can also display for different viewports. Once the window parts' detail levels are established, set each viewport to display the desired Detail Level when creating the viewport, or set this from the Object Info palette.
Vectorworks automatically produces window representations in low, medium, and high detail levels for display at different scales, but some window parts are left for you to determine.
Parameter
Description
2D Detail Levels
For each part, set whether/how it should display at each detail level. Use the Top/Plan Preview to view the settings at the desired detail level.
3D Detail Levels
For each part, set whether/how it should display at each detail level. Use the 3D Preview to view the settings at the desired detail level.
The Muntins list item controls the display for all muntins in the window.
Trim controls interior and exterior window trim.
Window settings: ID Tag pane
The Data Tag tool provides more flexible options for tagging windows; see Adding data tags and labels.
Parameter
Description
Include on schedule
Includes this window’s information in the window schedule; see Creating reports and Using preformatted reports
Show tag in 2D
Displays the ID tag in Top/Plan view
ID Prefix
Places a prefix before the label value
ID Label
Enter a label to identify the window
ID Suffix
Places a suffix after the label value
ID Class
To control visibility and, if Use ID class attributes is selected, appearance, select a class from the list of classes present in the drawing, or create a new class. Select <Window Class> to place the ID class attributes in the same class as the window object.
Uses the ID class attributes for the bubble line, leader line, and leader line marker
Keep ID horizontal
When selected, automatically rotates the ID so that it is horizontal
Bubble Shape
Select the ID tag bubble shape
Bubble Size
Enter the minimum bubble size (this value represents the bubble size times the layer scale; the bubble shape is maintained relative to the text inside it for ID bubble uniformity throughout the drawing file)
Bubble Line Attributes
Select the bubble line attributes and weight, or select Set Thickness to open the Set Thickness dialog box for creating a custom line thickness
Show leader
Draws a leader line from the ID tag to the window object
Line Attributes
Select the leader line attributes and weight, or select Set Thickness to open the Set Thickness dialog box for creating a custom line thickness
Include marker
Includes a marker for the ID leader line and choose the desired style from the marker list, or select Custom to create a custom marker. Select Edit Marker List to open the Edit Marker List dialog box; see Editing the marker list.
Show tag in 3D
Displays the ID tag in 3D views
Horizontal Offset
If Show tag in 3D is selected, enter the horizontal offset of the 3D ID tag relative to the bottom left corner of the rough opening when looking at the exterior side of the window (a positive value moves the tag inside the opening relative to the starting corner; a negative value moves the tag outside the opening relative to the starting corner).
The ID tag is offset slightly from the outside face of the window sash. The size and shape of the text and bubble, if present, will match the plan settings, and the text will always be right reading from the outside of the wall. The bubble will scale with text scaling in viewports.
Vertical Offset
If Show tag in 3D is selected, enter the vertical offset of the 3D ID tag relative to the bottom left corner of the rough opening when looking at the exterior side of the window (a positive value moves the tag inside the opening relative to the starting corner; a negative value moves the tag outside the opening relative to the starting corner)
Window settings: Configuration: Folding pane
Parameter
Description
Hang Position
Select how the sashes are hung from the track
Show sashes in both open and closed states
Shows both the open and closed representations of sashes in Top/Plan view. This option has no effect when the Open Angle is set to 0°.
Show in Alternate Path Class
When Show sashes in both open and closed states is selected, specify which Top/Plan representation to display with attributes of the Alternate Path class.
The Closed Sashes option always displays sashes as single lines.
Operable Sashes
Select which sashes to set as Operable Sashes. For both the Left and Right sashes, the Start sash is closest to the frame, and the End sash is farthest from the frame.
Show operable sash swings
Displays operable sash swings in Top/Plan view in the Alternate Path class
Window settings: Corner Window pane
Corner Window options are not enabled for non-rectangular window shapes or for curtain wall windows.
Parameter
Description
Corner window
Redraws the current window as a corner window.
Settings that do not apply to a corner window may be disabled or changed when the corner window option is selected.
When you click OK to exit the Window Settings dialog box, the window is moved to the corner of the wall to which it is most closely located. To complete the corner window, insert another one into the adjacent, attached wall.
Corner windows do not work in tandem with one another. When you make adjustments to one window, you also need to update the other. This can be accomplished quickly with the Eyedropper tool or from the Object Info palette. When you make adjustments to the wall containing a corner window, the window moves along with the wall and remains locked in the corner position. When adjusting the angle of the wall, the miter is automatically adjusted in most cases; if a corner window object does not automatically update, temporarily change a parameter from the Object Info palette to force a reset of the window object.
Span wall
Automatically adjusts the width of the window to match the span of the wall, and miters the window edges to the wall corners; therefore, the Width parameter in the General pane and Object Info palette is grayed
Corner Condition
Select the type of corner window:
Opening: creates a simple opening in a wall for defining a window break without creating any geometry to represent the window (the Configuration also changes automatically to Opening).
Cased Opening: creates a simple opening in a wall with geometry outlining the window break. Configuration is set to Cased Opening.
Flush Glass/Flush Glass - No Sash: draws the glass right to the edge of the wall and wraps it around the corner, and sets the Configuration on the General pane to Fixed Glass.
Mitered Sash: draws the window with a mitered sash in the corner.
Corner Post: draws the window with a post in the corner; specify the Size of the post and its Offset within the wall.
Window settings: Frame pane
Frame options are not enabled for the Opening Configuration.
Parameter
Description
Frame Width
Enter the face width of the window frame (parallel to the wall)
Frame Depth
Enter the depth of the window frame (perpendicular to the wall)
Use wall depth
Sets the frame depth to the overall wall depth
Use frame extension
Select this field to specify a frame extension to fill any gap between the interior face of the frame and the interior face of the wall; enter the desired Frame Extension Width.
In 2D views, extensions use the Frame line types and weights; in 3D views, the extension fill color and/or textures and visibility are controlled by the Interior Frame class.
Shim Gaps
Sets the distance between the frame and the rough opening for each side of the window. Windows in a door and window assembly don't model shim gaps.
Use wall provided gaps
Sets the gaps on all four sides to those specified by the wall closure profile offsets, calculated with the window's Size Reference from the General pane; see Wall closure settings
Left/Right/Top/Bottom
When wall-provided gaps aren't used, enter the gap value for each of the four sides, or click the Link button to match the gap to the one above it
Masonry Module
Enter the masonry module dimension
Window settings: Sash pane
Sash options are not enabled for the Opening Configuration.
Parameter
Description
Sash Width
Enter the sash width
Sash Depth
Enter the sash depth
Sash Offset
Enter the offset of the sash relative to the frame depth (a positive value moves the sash toward the window exterior; a negative value moves the sash toward the window interior)
Sash Width Offset
Enter the sash width offset relative to the frame width (leaving the default value of 0 keeps the sash adjacent to the frame, and a positive value makes the sash intersect the frame; a negative value is not permitted)
Glass Offset
Enter the glass offset relative to the sash depth (a positive value moves the glass toward the window exterior; a negative value moves the glass toward the window interior)
Unequal sash
Creates a double hung window with an unequal sash height; enter the desired Sash Scale Factor for the top sash.
Picture Window Slider Operation automatically has Unequal sash selected and disabled to differentiate it from a Slider Configuration with an XOX operation. Enter the desired scale factor for the sashes. The sash scale factor applies to both the left and right sliders.
Glazing Thickness
Enter the glazing thickness for the sash
Window settings: Sill pane
Sill options are not enabled for the Opening Configuration or for non-rectangular window shapes, or for curtain wall windows.
Parameter
Description
Include sill
Includes a sill
Sill Type
Select the sill type and whether to include a stool, and specify the measurements; sill measurement options depend on the Sill Type selected.
Timber sills align with the wall as follows:
In a wall, the rear of the sill is aligned with the interior face of the core component.
In an assembly not in a wall, the rear of the sill is aligned with the interior face of the window's frame.
Masonry or brick sills align with the wall as follows:
In a wall, the rear of the sill is aligned with the exterior face of the core component.
In an assembly not in a wall, the rear of the sill is aligned with the exterior face of the window's frame.
Window settings: Louvers pane
Louver options are not enabled for the Cased Opening and Opening Configuration. Fixed Glass is the recommended Configuration. To use louvers in a corner window, select Mitered Sash or Corner Post for the Corner Condition.
Parameter
Description
Replace glazing with louvers for
Replaces the glazing in the Transom and/or Sash with louver vents
Louver Type
Select the louver style and specify the measurements
(1) Blade Spacing
Enter the center to center distance between the blades
(2) Blade Angle
Enter the angle of the louver blades
(3) Blade Lip/Thickness
Enter the height of the visible lip/thickness of the blades
(4) Louver Depth
Enter the depth of the louvers, typically the same as the Sash Depth on the Sash pane
Window settings: Transom pane
Transom options are not enabled for the Opening Configuration or for non-rectangular window shapes, or for curtain wall windows.
Parameter
Description
Sash
Sash Width/Depth
Enter the transom sash width/depth
Sash Offset
Offsets the sash from the center of the frame. A positive value moves the sash toward the exterior of the window, and a negative value moves the sash toward the interior of the window.
Mullion
Mullion Width/Depth
Enter the transom mullion width/depth
Use frame depth
Overrides the transom Mullion Depth with the frame depth.
When this field is selected, Mullion Depth is grayed.
Muntins
Include muntins
Adds muntins to the transom
Pattern
Select the transom muntin pattern
Vertical/Horizontal Bars
For colonial muntins, enter the number of vertical/horizontal muntin bars.
Prairie and renaissance muntins come with pre-set configurations; therefore, any number of Vertical/Horizontal Bars specified are disregarded.
Bar Width/Depth
Enter the transom muntin bar width/depth
Bar Offset
Enter the transom muntin bar offset
Number of Rays
For sunburst patterns, enter the number of muntin rays
Glazing Thickness
Enter the glazing thickness for the transom
Window settings: Trim pane
Trim options are not enabled for the Opening Configuration or for curtain wall windows.
Parameter
Description
Include interior/exterior trim
Includes interior/exterior trim
Width/Depth
Enter the interior/exterior trim width and depth
Include trim under stool/sill
Includes interior/exterior trim along the window bottom
Window settings: Lintel pane
Lintel options are not enabled for the Opening Configuration or for non-rectangular window shapes, or for curtain wall windows.
Parameter
Description
Include lintel
Adds a lintel above the window or transom
Interior/Exterior Protrusion
Enter the interior and exterior lintel protrusion
Thickness
Enter the lintel thickness
Angle
Enter the lintel angle
Drop
Enter the length of the lintel drop
Window settings: Muntins pane
Muntin options are not enabled for the Opening Configuration or for non-rectangular window shapes.
Parameter
Description
Top sash/Bottom sash
Adds top and/or bottom sashes to the muntins
Pattern
Select the muntin pattern
Bar Width/Depth
Enter the muntin bar width/depth
Bar Offset
Enter the muntin bar offset
Number of Rays
Custom top sash muntins
For a double hung window with an unequal sash and colonial muntins, customizes the top sash; enter the desired number of Horizontal Bars
Window settings: Interior Shutters pane
Interior Shutter options are not enabled for the Opening Configuration or for non-rectangular window shapes, or for curtain wall windows.
Parameter
Description
Include interior shutters
Includes interior shutters
Use custom width
If Square is selected as the window’s Top Shape, creates interior shutters of a width other than the default value (1/2 the width of the window); enter the custom width
Frame Depth
Enter the depth for the interior shutters
Offset from Frame
Enter the offset distance from the interior edge of the window frame that shutters will be positioned when fully opened
Panel shutter
Creates paneled shutters
Panel Frame Width
Enter the rail and stile width of the paneled shutter
Number of Panels
Select One panel per sash to divide shutters at sash divisions or select to divide panels equally by the Custom number of panels specified
Custom shutter
Click Choose Symbol to select a custom shutter symbol from default content; see Concept: Resource libraries.
Custom shutters must be 3D-only symbols made from generic solids, saved in the default content location.
Window settings: Exterior Shutters pane
Exterior Shutter options are not enabled for the Opening Configuration or for non-rectangular window shapes, or for curtain wall windows.
Parameter
Description
Include exterior shutters
Includes exterior shutters
Use custom width
If Square is selected as the window’s Top Shape, creates exterior shutters of a width other than the default value (1/2 the width of the window); enter the custom width
Frame Depth
Enter the depth for the exterior shutters
Offset from Frame
Panel shutter
Panel Frame Width
Number of Panels
Custom shutter
Window settings: Centerline Marker pane
Centerline Marker options are not enabled for curtain wall windows.
Parameter
Description
Centerline marker
Displays a centerline marker in Top/Plan view
Size
Set the size of the centerline
Class
To control visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Window Class> to place the centerline marker attributes in the same class as the window object.
Line Attributes
Select the line attributes and weight, or select Set Thickness to open the Set Thickness dialog box for creating a custom line thickness. If Use class attributes is selected, the line attributes are set by the part’s class.
Include marker
Includes a marker at the end of the line; choose the desired style from the marker list, or select Custom to create a custom marker. Select Edit Marker List to open the Edit Marker List dialog box; see Editing the marker list. If Use class attributes is selected, the marker attributes are set by the part’s class.
Sets the centerline marker’s attributes (including marker style) by class rather than the parameters in the Window Settings dialog box
Window settings: Materials and Classes pane
Materials and classes can be set for individual window parts. If a material resource is used to define a part, the material typically provides the fill, texture, physical attributes, and construction information needed for drawings, renderings, and reports. The class controls the part's appearance and visibility. The visibility of the overall 3D window is controlled by the Class setting from the Object Info palette.
Parameter
Description
Window parts
Lists all parts that can be assigned an individual material, class, and texture. Some parts are divided into interior and exterior sides, that can be set separately. Two By Style columns indicate whether the part's material is set by style or instance, and whether the class and texture are set by style or instance.
Select one or more rows, and click in the applicable columns to do any of the following:
Select a material from the Resource Selector.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Window Class> to place the part attributes in the same class as the window object.
Select a texture from the Resource Selector, or click one of the buttons to use no texture, to use the class texture, or, if the selected item's material texture was previously overridden, to revert to the material's texture.
The material, class, and/or texture of all selected parts are assigned.
For windows with an Opening Configuration, in a 3D view, a no fill/no pen weight extrude completely fills the wall in place of the window; this extrude is placed in the Interior Frame class and is filtered out in IFC export operations. Change the class settings to control the visibility of the extrude.
ArchitectWindow settings: Energos pane
Windows play a critical role in energy analysis calculations. Energy is lost through the window glass, but energy is also gained by solar radiation through the window glass. Accurately determining the R-Value/U-Value and the shading factor is essential for the overall energy analysis.
Vectorworks Architect is required to conduct an energy analysis; however, energy-related parameters can be specified here for informational purposes.
Parameter
Description
Include in calculations
When selected, the window is eligible to be included in energy calculations, depending on the energy analysis settings for layer/class, element inclusion, and so on
R-Value/U-Value
Automatic Calculation
Based on the frame and glazing parameters, the window R-Value/U-Value is calculated and displayed. This value, along with the window shading factors, is critical for a correct assessment of the building envelope in energy calculations.
Manual Input
Select this option to override the calculated R-Value/U-Value and enter a manual value for the window instead. For complex or detailed window designs, enter results from a third-party calculation here.
Frame
Select the thermal properties of the frame. Sets can be created and edited; see Specifying system sets.
Glazing
Select the thermal properties of the window glazing. Sets can be created and edited; see Specifying system sets.
Shading
Select the level of shade for each type of shading near the window, or select Custom from any of the lists. The Edit Shading dialog box opens, to manually enter a percentage for when the window is in the shade.
General
Select the general shade conditions where the window is located
Surrounding
Specify surrounding shade conditions that might affect the amount of solar radiation reaching the window
Summer Shading
Specify special shade conditions that apply during the summer months (for example, when nearby deciduous trees shade the window)
Additional Shading
Select any mechanical or passive shading mechanisms in place, or select Custom and enter a shading percentage in the Edit Shading dialog box
Summer Ventilation
Opens the Summer Ventilation Settings dialog box, to specify summer ventilation options for when the window is typically open.
Type of usage: (ground floor, upper floor, night): Select the type of ventilation system usage, if any, for the window.
Operable opening width: Indicates the width of the window opening gap for an operable window (which affects the amount of ventilation).
Window settings: Data pane
Certain data fields cannot be edited.
Parameter
Description
Field Name/Field Value
Data fields are listed under Field Name. Click the Field Value column to enter data for use in the window schedule, as needed.
Window settings: Object Info palette
If the window has been inserted as a plug-in object, most settings from the Window Settings dialog box display on the Object Info palette. If the window is a black symbol made from a window object, fields pertaining to window geometry do not display. See Concept: Vectorworks symbols. The fields in the Object Info palette are named similarly (but not always identically) to those in the Window Settings dialog box, and roughly reflect the order in which settings are entered in the dialog box, for ease of editing. Curtain wall windows have limited parameter options. For widows using object styles, the parameters that are set by style display for informational purposes but cannot be edited from the Window Settings dialog box or the Object Info palette.
To edit window parameters in the Window Settings dialog box, click Settings from the Object Info palette, double-click the window to open the Window Settings dialog box, or right-click on a window and select Edit from the context menu.
Most window parameters are described in in the settings panes above. Only the parameters that are different in the Object Info palette are described here.
Parameter
Description
Insert
For windows in a wall, specify where to insert the object relative to the wall, its core component, or its designated insert location
Offset
Enter the offset of the insert perpendicular to the wall's path
Flip
Click to flip the orientation of windows inserted in a wall; relevant parameters set by instance are changed to match the window's new orientation. See Interactive handing of doors and windows for a visual way to change window orientation and related parameters.
Set Position
Click to activate the Move by Points tool in Reference Point mode and move the window by a specified distance from a reference point
Wall Closure
For windows in a wall, opens the Wall Closure dialog box; see Wall closure settings.
See Additional plug-in object style and instance options for information on wall insertion options in the Plug-in Object Style Options dialog box or Plug-in Object Options dialog boxes.
Style
Replace, remove, or edit the current style, or create a new plug-in object style for this object; see Changing plug-in object styles from the Object Info palette.
Editing a style changes all instances in the file that use the style.
Select From Catalog
For a plug-in object style with the catalog item set by instance, see Selecting catalog items for plug-in object styles
Hide style parameters
Hides the parameters that are set by style and by catalog; these cannot be edited from the dialog box or Object Info palette
List box functionality
Doors and Windows
Energos energy analysis module
Window terminology specific to the UK, Australia, and New Zealand
Wall display with design layer cut plane
Setting design layer properties
