Design SuiteNavigating among instances of the same phased object
When an object is removed from one location and placed in a different location, multiple instances of the same object are created. Each instance has its own set of phasing data. However, the various instances/locations of the same object are linked; you can navigate from a selected instance to another instance of the same object in the drawing.
Buttons and commands in various locations provide options.
Place Object for Relocation for an object that has been removed and stored, but not yet placed elsewhere in the drawing
Navigate to Removed Instance of a relocated object
Navigate to Relocated Instance of a removed object that has been placed elsewhere in the drawing
When navigating to another instance, the phase and view change as needed to show the instance in the drawing window.
Navigate among linked instances from multiple locations.
The Object Info palette for a removed or relocated object
The Object Phasing section of the context menu when you right-click on a removed or relocated object
The Phasing palette - Removed Objects, where all removed, stored, and relocated objects are listed, along with the phases they were removed and relocated
Demolishing or removing a phased object
Relocating a removed object
Tracking removed objects in the Phasing palette
Managing object phasing on the Object Info palette
