Spotlight or ConnectCADPower patching the electrical system
Power patching is the process of connecting electrical devices to convey power through a system. In Spotlight, "electrical devices" include the distributor and lighting device symbols in the Vectorworks libraries, as well as custom distributors created with the Edit Internal Wiring command (see Editing distributors for details).
Once the electrical devices you need are created or chosen from the available content, place them in the drawing and proceed with power patching. There are several ways to power patch devices from the drawing or the power schematic (see Concept: Power schematics).
The power requirements of the electrical system are calculated automatically; the power consumption of all electrical devices connected in a daisy chain configuration is summed at the distributor. The electrical workload for the entire drawing can be viewed and edited from the power schematic and reported in worksheets.
Power patching with the Cable tool
Tool
Workspace: Tool set
Cable
Design Suite and Spotlight: Cable/Power Planning
ConnectCAD: Cable Route
The Cable tool connects electrical devices by drawing cables between them.
To power patch with the Cable tool, see Drawing cables, Single cable connection, and Multi cable connections.
Power patching from the Object Info palette
Power Information parameters display on the Object Info palette of electrical devices, including the distributor and lighting device symbols in the Vectorworks libraries and any custom devices created by inserting electrical components. The parameters depend on the device's components. For example, a distributor that functions as a power source has a single power source component, which generates one output field. By contrast, a distributor that functions as a plugbox with 16 output components, has 16 output fields and one input field.
You can display the power information for seven components at a time. Choose which set of components to display from the Select Range list on the Object Info palette. The sets are numbered according to the component stacking order.
Each electrical device, and each electrical component within it, has a unique ID. This ID is used globally for power patching. The distributor ID is set by the ID field; the lighting device ID is set by the Channel field; and the electrical component ID is set by the Name field on the Object Info palette. Power patch the electrical system by selecting the appropriate object ID for the input and output connections in Power Information. A list of the available connections displays for each input and output.
If you are an advanced user who creates custom electrical devices, you can specify the internal component connections from the Object Info palette of an electrical component. Otherwise, all electrical devices can be power patched from their Object Info palette.
To automatically draw cables between the patched devices, the option to Automatically create cables when devices get connected must be selected in the Cable Preferences; see Setting cable preferences. The cables will follow existing cable paths and truss paths if the option to Automatically follow paths when a cable is drawn is selected.
Device connections
Connect electrical devices from the Power Information parameters on a device's Object Info palette. The available parameters depend on the number and type of electrical components in the device symbol.
To power patch devices from the Object Info palette:
Select an electrical device in the drawing.
In the Object Info palette, do one of the following:
If the selected device will receive power, an Input field displays with a list of the connection options. Select the desired output socket for the input connection; the corresponding Output field is updated on the source device.
A lighting device displays the current power connection in Power In; you can search for and select a different connection from the list.
If the selected device will supply power, an Output field displays with a list of the connection options. Select the desired input socket for the output connection; the corresponding Input field is updated on the target device.
A check mark displays next to the connection name that is currently in use, and power parameters display below. If the connection you selected is already in use, an alert opens; click Yes to confirm that you want to override the existing connection. You can elect to do the same override action during this operation for any remaining connections in use.
If cables were automatically inserted, they may need to be edited; see Editing cables.
Component connections
For advanced users who create custom electrical devices, several of the internal components can be power patched from their Object Info palette. These include the input, output, and overcurrent protector components. See Editing distributors for information about inserting electrical components in custom devices.
ConnectCADPower patching by command
Command
Workspace: Path
Power Patch Selected Objects
Power Patch Position
Design Suite: Entertainment > Cable/Power Planning
Spotlight: Spotlight > Cable/Power Planning
Connect electrical devices by command:
Power Patch Selected Objects patches all the selected electrical devices.
Power Patch Position patches all the electrical devices at the location of the distributor's load (the Position parameter in the Object Info palette of a selected distributor).
The following rules apply when power patching by command:
The order in which the devices are connected is based on the distance from the distributor.
Only one connection per output is possible.
Only connections with compatible connectors are possible.
Outputs and inputs that are already in use are ignored.
The Location parameter of a distributor object must match the Position Name of the hanging position to which it is attached.
To automatically draw cables between the patched devices, the option to Automatically create cables when devices get connected must be selected in the Cable Preferences; see Setting cable preferences. The cables will follow existing cable paths and truss paths if the option to Automatically follow paths when a cable is drawn is selected. If you have created a power schematic (see Creating a power schematic), power patching on the light plot creates circuits on the associated devices on the schematic.
To power patch devices by command:
Do one of the following:
Select the electrical devices to patch, and select Power Patch Selected Objects.
Select a lighting position object to patch the attached devices, and select Power Patch Position.
Connect breakouts to distributor racks before patching by position to avoid chaining breakouts together.
Cables are automatically inserted to connect the devices. To edit the cables, see Editing cables.
Power patching with the power schematic
Patch the electrical system by using the power schematic to view and edit the electrical device connections. Edits to the connections on the power schematic are reflected on the light plot (see Creating a power schematic).
Tracing a power source to its origin
Any object that participates in the power system, including both native consumer devices such as lighting devices and objects to which an input or consumer power component has been added, can have have its power traced back to the original source. When an object participates in the power system, a Power Information section is added to the Object Info palette.
To track the power source of a selected object:
Select an object that participates in the power system.
In the Object Info palette's Power Information section, click Select Power Source.
The object's immediate power source is selected in the drawing area, and becomes active in the Object Info palette. If that object isn't the origin of the power, Select Power Source is available for it as well.
Continue to click Select Power Source for sequential objects until you trace back to the origin.
Cables and power planning
Placing distributors
Drawing cable paths
Drawing cables
Editing cables
