Placing connector panels
Tool
Workspace: Tool set
Connector Panel
Design Suite, Spotlight: ConnectCAD Schematics
ConnectCAD: Schematics
The tool places audio or video connector panels. Panels can be associated with equipment items in the layout view; see Creating connector panel layouts.
Mode
Description
Single Click
Places a single connector panel at the click location
Linear Array
Places an array of connector panels along the drawn line
Connector Panel Input
Inserts an input type of connector panel
Connector Panel Output
Inserts an output type of connector panel
Panel
Select the panel name for the connector panel location. If the panel does not yet exist, create a new one by selecting New. Enter the new panel name in the Add New Panel dialog box.
Port/Number
Assign a port code and number (if applicable) combination. The port name must be unique for each device. Select --- to indicate no port number.
Cable Connector
Select the cable or chassis connection type. The list of available connectors displays according to priority (uncategorized, preferred, custom, workgroup, and default) and can be customized (see Specifying ConnectCAD settings).
To insert a connector panel:
Click the tool, and select the placement mode.
From the Tool bar, select the type of connector panel to place by clicking the mode.
On the drawing, green indicates an input connector, and red indicates an output connector.
Enter the Port number.
Specify the Panel and Number by selecting the values from the lists on the Tool bar. Create a new panel if needed.
If you continue placing the same connector panel device, the Number automatically increments.
If you do not want to specify a Number for a single connector panel device, select ---.
Click to place the connector panel into the drawing. If placing the device into an existing circuit, the device splits the circuit.
In Single Click mode, click once to place the object.
In Linear Array mode, click once to start the array; move the cursor to set the distance and direction of the linear array. Press the Shift key to constrain to the horizontal or vertical direction. The preview indicates the spacing and placement of the objects; the floating Data bar shows the Count. Click to place them.
The device can be edited later from the Object Info palette.
Parameter
Description
General
Device Name
Displays the device name for use in reports; by default, a device prefix followed by the panel ID displays.
If associating the connector panel with an equipment item object, name the device identically to that of the associated panel layout on the Rack Elevation layer (for example, CTP_BOX1).
Device Type
Displays the type of device
Label Symbol
Displays the symbol selected for the device label; select a different symbol definition from the list if desired. The options include different locations for the tag and description labels.
Display Tag
Enter the tag name (normally this is the panel and number of the device) for display on the drawing
Description
Enter a description, such as the manufacturer and model name, for display on the drawing
Manufacturer
Enter the make and model for use in reports
Save as Symbol
Does not apply to connector panels
Physical
Height/Width/Depth
Enter the dimensions of the device
Power (W)
Enter the power requirements of the device in watts
Auto BTU calculation
Automatically converts the power requirements of the device from watts to BTU units (BTU = power in watts x 3.41)
BTU
To enter power requirements manually, deselect Auto BTU calculation and enter the power requirements of the device in BTU units
Weight (kg)
Enter the devices's weight in kilograms
Height RU
Select the height of the device in rack units
Rack Width
Select whether the width of the device is constrained by the half or the full width of the equipment rack. Select non-rack to use any width, unconstrained by the rack or not placed within a rack. (See the Rack Width description in Placing equipment.)
Configuration
Modular
Indicates that the device is a module that fits in a rack frame
Number of slots
For modular devices, enter the number of frame slots required in a rack frame
Location
If an associated equipment item already exists in the layout, displays the device location; otherwise, if you want to assign the device to a layout, enter the location for the corresponding equipment item
Room
Enter (or displays) the name of the room
Rack
Enter (or displays) the name of the equipment rack; the rack name displays on the device
Rack U
Select (or displays) the position of the device in rack units; the value displays on the device
Slot
Enter (or displays) the slot position, if the device is placed in a rack frame
Edit Device Array
Opens the Connector Panel Settings dialog box. Specify data for the selected device or devices.
Connector Type: Select whether the connector panel is an input or output type.
Panel: Select the panel value.
Port/#: Assign a port code and number combination. The port name must be unique for each device.
Renumber ports: If multiple devices are selected, click Renumber ports, and then select the port number to use from the list.
Cable Connector: Select the cable connection type. The list of available connectors displays according to priority and can be customized (see Specifying ConnectCAD settings).
Chassis Connector: Displays the chassis connector that corresponds to the selected cable connector. On custom panels, chassis connectors must be the opposite gender of their cable connectors.
# Circuits: Specify the number of circuits to create, for a multi-circuit connector.
Concept: Specialized device types
Concept: ConnectCAD devices
Building a device
Adding sockets, loops, and terminators
Editing devices, sockets, and adapters
ConnectCAD
