Detailed space area settings
Tool
Workspace: Tool set
Space
Design Suite, Architect, Landmark: Space Planning
Spotlight, ConnectCAD: Add tool to workspace (see Customizing workspaces)
Use the Detailed Space Area Settings dialog box to create and edit detailed space area calculation rule sets that combine how each subarea affects the total space area. Each file can contain multiple rule sets to meet a variety of required standards, and can be used to create a range of reports, from IFC calculations to material take offs.
To open the Detailed Space Area Settings dialog box:
Do one of the following:
Click the tool and then click Preferences. On the Space Area pane, click New or Edit under Detailed Space Areas.
Select one or more existing space objects and, then click Settings on the Object Info palette. On the Space Area pane, click New or Edit for a selected area under Detailed Space Areas.
Select one or more existing space objects and, with a space area selected under Select Space Area, click Edit Selected Space Area from Space Area section of the Object Info palette.
The Detailed Space Area dialog box opens. Most panes provide a schematic plan and schematic section clarifying which parts are controlled on that pane.
For objects to be included in the calculation based on their size, select one of the following comparison operators.
 Greater than
 Less than
 Greater than or equal to
 Less than or equal to
 Equal to
These document-wide settings apply to all spaces in the file, except for the settings that must be controlled by individual space polygons.
Detailed space area settings: Window Niche pane
Parameter
Description
Add Window Niches to Space Area
Select which niches to add to space areas: none, all, or only those that fit the specified size parameters
Size parameters
When adding only the niches that fit the specified size, select the parameters to include in the calculation, the comparison operator for each parameter, and enter the measurement.
For Height (8), select the height reference, and add or subtract any needed offset.
Add Niche up to
Select whether the niche measures to the border or center of the window frame
Detailed space area settings: Door Niche pane
Parameter
Description
Add Door Niches to Space Area
Size parameters
For Height (8), select the height reference, and any needed offset.
Add Niche up to
Select whether the niche measures to the door's threshold, centerline of leaf, centerline of the wall, or the entire door
Detailed space area settings: Wall pane
Parameter
Description
Use only All Walls settings
Uses the same All Walls tab settings for all of the wall types
Interior Walls/Exterior Walls/Plumbing Walls/All Walls
If not using All Walls settings for all wall types, click a tab, and specify the settings for each wall type
Confining parameters
Select whether the space will ignore (not be confined by) all the walls of each type, all be confined by all the walls, or be confined only by walls of a specified size. When considering only the walls that fit the specified size, select the parameters to include in the calculation, the comparison operator for each parameter, and enter the measurement.
Add Space Area up to
For confined walls, to count part of the wall's footprint, select the reference for the space area's depth limit
Detailed space area settings: Column pane
Parameter
Description
Add Footprint of Columns and Pilasters to
Select which columns/pilasters to add to space areas: none, all, or only those that fit the specified size parameters
Area
When adding only the columns/pilasters that fit the specified size, select the comparison operator, and enter the measurement
Detailed space area settings: Wall Recess pane
Parameter
Description
Add Recesses in Walls to Space Area
Select which wall recesses (see Creating wall recesses) to add to space areas: none, all, or only those that fit the specified size parameters
Size parameters
When adding only the wall recesses that fit the specified size, select the parameters to include in the calculation, the comparison operator for each parameter, and enter the measurement.
For Height (6), select the height reference, and any needed offset.
Detailed space area settings: Wall Projection pane
Parameter
Description
Add wall Projections to Space Area
Select which wall projections (see Creating wall projections) to add to space areas: none, all, or only those that fit the specified size parameters
Size parameters
When adding only the wall projections that fit the specified size, select the parameters to include in the calculation, the comparison operator for each parameter, and enter the measurement
Detailed space area settings: Slab Modifier pane
Parameter
Description
Consider Clip/Add Modifiers in Slabs
Select which slab modifiers should clip from or add to space areas: none, all, or only those that fit the specified size parameters
Size parameters
When considering only the slab modifiers that fit the specified size, select the comparison operator, and enter the measurement
Detailed space area settings: Deduction Factors pane
Parameter
Description
Area Modifier on Entire Space Area (%)
Select whether the area modifier applied to the entire space area is set by a rule for all space areas in the file  or by the individual space polygon , and enter the percentage. When set by polygon, these settings can be changed in the Object Info palette. A setting of 100% doubles the space; 0 leaves it unchanged, and -100% makes the space area 0.
Deduction Factors on Space Area Modifiers
For each category, enter the deduction factor as a percentage for the space area modifier
Deduction Factor on Subareas Under Low Ceiling
If Height <
Select which areas to deduct under a low ceiling, enter the upper height limit for that area, and enter the deduction factors to reduce in percentages; see Modifying spaces with non-horizontal ceilings and floors
Show outline
Displays the contour line in the drawing
Detailed space area settings: Dimensions pane
Parameter
Description
Create Space Polygon if
To create a space polygon if a space area is a specified size, select the parameters to include in the calculation, the comparison operator, and enter the measurement
Offset from Inner Faces of Walls
Select whether the offset from inner faces of walls is set by a rule for all space areas in the file  or by the individual space polygon , and enter the offset
Detailed space area settings: Graphic Attributes pane
Parameter
Description
Graphic Attributes
Lists space area geometry that has graphic attributes settings.
The class and graphic attributes of each part of the object are displayed. Double-click a line to set attributes for the part; see The Attributes palette.
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Select <Space Class> to place the category in the same class as the space object.
Make All Attributes by Class
Sets all fill, pen, and texture attributes by class
Remove All by Class Settings
Removes all by class settings for fill, pen, and texture attributes
Creating spaces with the Space tool
Space settings
Space Area Manager
