Create and manage structural elements of the drawing using the Organization dialog box. This dialog box has specialized functions to sort and select its list items; see List Box Functionality.
To use the Organization dialog box:
Select Tools > Organization. Alternatively, click the Classes or Layers button from the View bar, or select Edit View from the Saved Views menu on the View bar.
The Organization dialog box opens.
Select the appropriate tab for the element to be created or edited: Classes, Design Layers, Sheet Layers, Viewports, Saved Views, or References.
In the Vectorworks Architect product, an additional Stories tab is available; see Creating and Managing Stories.
From the top of the dialog box, select either Details or Visibilities view.
Generally, the Details view shows the current settings for each element, and enables editing of layer and class visibilities in the drawing area; the Visibilities view enables editing of layer and class visibilities in viewports and in saved views (see Setting Visibilities in the Organization Dialog Box).
Buttons at the bottom of each tab provide creation and management functions. Alternatively, right-click (Windows) or Ctrl-click (Mac) on a list item to display a context menu, which has most of the same functions as the tab buttons.
If a description is entered for the class, it displays in a screen tip when you position the cursor over the class name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Click to show/hide the buttons.
The names of referenced design layers display in italics. If a description is entered for the design layer, it displays in a screen tip when you position the cursor over the layer name. If the layer is referenced, the screen tip also displays the full layer name and the source file name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
If a description is entered for the sheet layer, it displays in a screen tip when you position the cursor over the layer name. On Windows, click the disclosure arrow on the screen tip to collapse or expand it.
Click here for a video tip about this topic (Internet access required).
