DesignSeries00031.pngNotes management with databases
Instead of manually typing the text for every callout or keynote and general notes object, text that is used repeatedly—by one or many users—across projects and files can be stored in a tab-delimited text file (referred to as a “database”). The use of a database for storing notes saves time and prevents errors, and standardizes compliant notes usage across files.
There is no limit to the number of databases that can be used for annotating a drawing. The databases can have an unlimited number of notes of any length. After placement, notes can be easily updated if changes are made to a database.
Inserting callouts or keynotes
Editing keynote callouts and the keynote legend
Placing general notes
Managing database notes
Filtering database entries
Adding callout or general note text to a database
Adding text to a database
Reconciling database and drawing notes
Locating databases on a network
Converting notes from previous versions
Notes management
