Editing
cablesReshape a cable run by double-clicking on it, or by right-clicking on it and selecting Edit Path from the context menu. The Reshape tool is automatically activated to reshape the object. After reshaping, the cable run parts are regenerated using the correct number of parts based on the inventory and new cable length, and the connections update.
The Split tool splits an existing cable into multiple cable parts. Use this tool to split (break) cables in a specific spot, allowing control over the location of connectors in the cable run. For example, if you need to note a cable break for a door that must be allowed to open and close, or a truss that has to move into position at a different time from another truss. Split cables share the same Cable Run ID and connections.
Cable objects can be directly edited from the Object Info palette, and the cable appearance is edited by clicking Settings from the Object Info palette. For cables using object styles, the parameters that are set by style display for informational purposes but cannot be edited. Many of the Object Info palette parameters are for informational and reporting purposes.
Click
to show/hide the parameters.
When using a cable style, the cable appearance, type, connectors, and class settings are preset. The settings can be adjusted if needed, and a new cable style resource can be created.
To change the cable settings:
1. From the Object Info palette of a selected cable run, click Settings.
The Cable Settings dialog box opens.
Click
2.Optionally, create a style resource from the object (see Creating plug-in object styles)
A cable run is made up of cable parts of specific types, lengths, and voltages. The configuration of the cable run can be adjusted if needed.
To change the cable run configuration:
1. From the Object Info palette of a selected cable run, click Cable Configuration.
The Cable Configuration dialog box opens.
Click
2.The Cable Information area shows the Needed Length and the Current Length. Locate the needed available cable parts and move them to the Selected Parts list to construct the cable run configuration. Use the < and > buttons, or simply drag and drop the cable parts between the lists.
If needed, adjust the cables that are in the available parts list by clicking Manage Cable Parts. Review the cable inventory and make any required changes.
If connection errors occur during placement, the Cable Errors dialog box opens, listing the problems and the affected connections. A different distributor, cable style, or connector may be needed, or an adapter may be required. To avoid future connection errors, select Automatically use adapters for future connection errors. This will add adapters to affected connections, ensuring that the appropriate connections can be made, and the errors dialog box will no longer open.
