Connect00023.pngPlacing terminal panels
Tool
Tool set
Term Panel
Schematics
The tool places terminal panels, of the video, audio, optical, or data type, or a DIN Rail terminal panel.
Mode
Description
Single Click
Places a single jack or linked jack at the click location
Linear Array
Places an array of jacks or linked jacks along the drawn line
Video Term Panel
Inserts a video terminal panel
Audio Term Panel
Inserts an audio terminal panel
Data Term Panel
Inserts a data terminal panel
Optical Term Panel
Inserts an optical terminal panel
DIN Rail Term Panel
Inserts a DIN Rail type of terminal panel
Group
Assigns the panel to a named group of terminal panels. This extends the name space of large patching systems by adding a group prefix in front of the row/column value.
Panel/Port
The panel and port number are set according to the options in the ConnectCAD settings
Preferences
Opens the Term Panel Preferences dialog box, for setting default values
To insert a terminal panel or DIN rail panel:
1.      Click the tool, and select the placement mode.
2.From the Tool bar, select the type of terminal panel to place by clicking the mode.
3.Click Preferences to open the Term Panel Preferences dialog box. Specify the default information for the devices to place.
4.Specify the Group, Panel, and Port by selecting the values from the lists on the Tool bar. By default, the values from the ConnectCAD settings are applied (see Specifying ConnectCAD settings), but they can be overridden here.
If you continue placing the same terminal panel device, these values automatically increment.
5.Click to place the terminal panel into the drawing. If placing the device into an existing circuit, the device splits the circuit.
●       In Single Click mode, click once to place the object.
●       In Linear Array mode, click once to start the array; move the cursor to set the distance and direction of the linear array. Press the Shift key to constrain to the horizontal or vertical direction. The preview indicates the spacing and placement of the objects; the floating Data bar shows the Count. Click to place them.
The device can be edited later from the Object Info palette.
Concept: Specialized device type and prefix
Placing devices
Building a device
Adding sockets, loops, and terminators
Editing devices and sockets
ConnectCAD
