Spot00031.pngPlacing lighting pipe objects
Tool
Tool set
Lighting Pipe
Rigging
Insert and configure a lighting pipe object with the Lighting Pipe tool. Lighting pipe objects function as rigging objects, so lighting devices and other loads can attach directly to the lighting pipe. Lighting pipes support full 3D rotation, and they can be used to create schematic views.
In addition to individual objects created using the Lighting Pipe tool, it you can access a variety of standard lighting pipe resources and custom styles (see Concept: Plug-in object styles).
Mode
Description
Point Insertion
Inserts the pipe with two clicks, to place and set the rotation
Line Insertion
Inserts the pipe as a line to define the length
Polyline Insertion
Inserts the pipe using the polyline creation options
Length
For Point Insertion mode, sets the length of the pipe
Align Left
(Point Insertion mode only)
Inserts the pipe with a left-aligned insertion point
Center
Inserts the pipe with a center insertion point
Align Right
Inserts the pipe with a right-aligned insertion point
Vertical
Inserts a vertical pipe
Vertex
(Line Insertion mode only)
Inserts a pipe from its start point to its end point
Center
Inserts a line from its center point
Polyline creation options
(Polyline Insertion mode only)
For Polyline Insertion mode, selects the method for drawing the polyline upon which the object is based; see Creating polylines.
Preferences
Opens the object properties dialog box to set the default preferences for lighting pipes
Style
Opens the Resource Selector to select a symbol for placement; double-click a resource to activate it
To insert a lighting pipe object:
1.      Click the tool.
2.Do one of the following:
●       Click Style on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
3.Do one of the following:
●       Click Point Insertion mode and the needed insertion point alignment submode. Set the pipe Length.
●       Click Line Insertion mode and either click Vertex submode to place the pipe from start to end points, or Center submode to place it from the center to an end.
●       Click Polyline Insertion mode and use the polyline creation modes to insert the pipe.
Alternatively, create a polyline and then select the Create Objects from Shapes command (see Creating objects from shapes).
4.Click in the drawing area to draw the lighting pipe according to the modes selected.
5.Optionally, create a style resource from the object (see Creating plug-in object styles).
Inserting hanging positions
Concept: Hanging positions
Concept: Rigging objects
Connecting rigging objects
Event rigging and structural analysis
