DesignSeries02738.pngStair settings: Railings tab
The settings on the tab can be saved as a set and then loaded, replacing the current tab parameters.
Click the Railings tab to set the stair’s handrail and guardrail parameters. The Railings tab is divided into three panes. On the left, the handrail and guardrail categories display, along with each current setting for the left, right, or both sides of the stair. Handrail and guardrail parameters are set separately. Click a disclosure arrow to reveal handrail or guardrail parameter categories. Select a category to edit its parameter settings in the middle pane. On the right, three previews display the railing cross-section, top/plan stair view, and isometric stair view.
Parameter
Description
Railing Settings
Saves settings so they can quickly be applied again; see Using saved sets for stair settings
View
Determines the view to apply the parameters to the stair; depending on drawing settings like layer scale and the document preference Hide details, the detailed or schematic view status is displayed
Detailed
Applies the railing parameters to stairs in a detailed layer scale view
Schematic
Applies the railing parameters to stairs in a schematic scaled view
Accept for all views
Applies the railing parameters to stairs in all views (detailed and schematic)
Accept Settings for
Select the railing to which the current settings apply
Left/Right or Outside/Inside railing
Applies the parameters to the selected side only
Both sides
Applies the parameters to railings on both sides
Handrail
Show handrail
When selected, adds a handrail to the stair and enables the handrail parameters; Show displays for the handrail settings
Position
Height
Sets the vertical distance from the leading edge of the tread/nosing to the top of the handrail
Handrail Position
Select whether the railing is on the stair or next to the stair
Offset to Tread Edge
Indicates the distance between the edge of the stair (the solid structure or the stringers) and the handrail
Top Rail
Profile Type
Select the basic geometry of the top rail:
Line: A 3D polyline serves as the railing profile
Flat: A 3D polygon with width, but no height, serves as the railing profile
Round: The cross-section is round, controlled by width
Rectangular: The cross-section is rectangular, controlled by width and height
Width
Sets the width for flat, rough, and square top railing geometry
Height
Sets the height of rectangular top railing geometry
Bottom Extension
Specifies the distance the top rail extends past the leading edge of the first tread or start of the stair; select whether the bottom extension is horizontal to the bottom riser or slopes with the stair
Top Extension
Specifies the distance the top rail extends past the leading edge of the last/top tread/end of the stair; select whether the top extension is horizontal to the bottom riser or slopes with the stair
Guardrail
Show guardrail
When selected, adds a guardrail to the stair and enables the guardrail parameters; Show displays for the guardrail settings
Position
Height
Sets the vertical distance from the leading edge of the tread/nosing to the top of the guardrail
Guardrail Position
Indicates the distance between the edge of the stair (the solid structure or the stringers) and the guardrail
Top Rail
Create Top Rail
Select whether to create a top rail on the guardrail
Profile Type
Width
Height
Start at Bottom
Defines where the top rail of the guardrail begins:
At Post: The top rail begins at the first post
At Tread: The top rail begins at the stair tread
Extend Tread by: Sets a specific distance the top rail extends past the leading edge of the first tread or start of the stair. Select whether the bottom extension is horizontal to the bottom riser or slopes with the stair.
End at Top
Defines where the top rail of the guardrail ends:
At Post: The top rail ends at the last post
At Tread: The top rail ends at the stair tread
Extend Tread by: Sets a specific distance the top rail extends past the leading edge of the last/top tread/end of the stair. Select whether the bottom extension is horizontal to the bottom riser or slopes with the stair.
Frame
Create Frame
Select whether to create a frame on the guardrail
Frame Type
Sets the geometry for the area below the top rail, and between posts:
Frame: Adds a frame to support the frame bars; the frame must include at least one of the top, bottom, or left-right vertical supports
Panel: Adds a solid panel below the top rail
Top/Bottom/Left-Right Verticals
Select options to include in the frame
Offset to Top Rail
Indicates the perpendicular distance between the bottom of the top railing, and the top of the frame or panel
Offset to Stair
Sets the perpendicular distance between the leading edge of the tread/nosing or the bottom of the frame or panel
Profile Type
For Frame types, sets the frame cross-section geometry:
Width
Sets the width of the frame or panel
Height
Sets the height of rectangular profiles
Frame Bars
Create horizontal bars
Select whether to create horizontal frame bars
Create vertical bars
Select whether to create vertical frame bars
Profile Type
Sets the cross-section geometry of the frame bars:
Line: A 3D polyline serves as the frame bar profile
Flat: A 3D polygon with width, but no height, serves as the frame bar profile
Round: The cross-section is round, controlled by thickness
Rectangular: The cross-section is rectangular, controlled by thickness and depth
Thickness
Sets the thickness of round and square frame bar profiles
Depth
Sets the depth of rectangular frame bar profiles
Maximum Distance
Specifies the maximum distance between centerlines of frame bar geometry, setting the spacing of the frame bars
Create Posts
Select whether to create vertical supports of the top rail and frames
Shape
Sets the geometry of the guardrail posts:
Line: A 3D polyline serves as the post profile
Flat: A 3D polygon with width, but no depth, serves as the post profile
Rectangular: The cross-section is rectangular, controlled by width and depth
Width
Sets the width for flat, round, and rectangular posts
Depth
Sets the depth of rectangular posts
Arrangement
Determines how to place the posts
On each tread
Places one post at the midpoint of the tread depth for each tread
Distance (approx.)
Specifies the distance between each post
Placement
Links the post positions on the left and right sides of the stair based on one of these methods:
Each side individually: The post positions are calculated separately for each side of the stair based on the approximate Distance value
Left side has priority: The left side post distances are calculated based on the approximate Distance value; the posts on the right are placed symmetrically
Right side has priority: The right post distances are calculated based on the approximate Distance value; the posts on the left side are placed symmetrically
On each corner
Places a post at each landing corner, regardless of the distance set
Min. Distance
Specifies the minimum distance between a corner post and the next adjacent post on a landing
Previews
Three previews display:
The detailed plan and elevation view of a representative portion of the railing system
An overall top/plan view of the stair
An isometric view of the stair, when Component is set to 2D and 3D on the General tab
Stair settings: General tab
Stair settings: Geometry tab
Stair settings: 2D Graphics tab
Stair settings: Construction tab
Stair settings: Graphic Attributes tab
Saving a stair as a symbol
Setting minimum and maximum values for stair geometry
Stair properties
Transferring stair properties
Creating a stair
Reshaping stairs
