Architect or LandmarkEditing hardscape objects
There are several different ways of editing hardscape objects, depending on the type of hardscape and the desired outcome.
Modification
Description
Editing the hardscape properties
Hardscape properties
Reshaping the hardscape or path
Reshaping a hardscape object
Aligning hardscapes with surrounding geometry
Aligning hardscapes or modifiers with existing geometry
Modifying an aligned surface type
Editing aligned hardscapes or modifiers with surface modifiers
Editing aligned hardscapes or modifiers with profile lines
Converting a hardscape configuration
Converting a hardscape object to different configuration
Editing hardscape fills and joint patterns
Modifying hardscape tag appearance
Hardscape tag appearance
Creating a section view of a hardscape
Workflow: Creating a section view of a hardscape
