Editing plant styles
Edits to the plant style immediately affect all plants in the drawing that use the style. Edits affect the copy of the plant style in the active file, not the master plant style in the main library.
To edit an existing plant style, do one of the following:
Select AEC > Plants > Plant Style Manager (Design Suite workspace) or Landmark > Plant Style Manager (Landmark workspace) to edit plant style parameters from the Plant Style Manager.
Right-click on a plant instance; select Edit from the context menu, and then click Style to edit the plant style's parameters.
Select a plant instance, and from the Object Info palette's Style parameter, select Edit Style.
From the Resource Manager, right-click on the plant style, and select Edit Style from the context menu.
From the Edit Plant Style dialog box or Plant Style Manager, set the plant style parameters and graphics as described in Plant settings and Plant Style Manager.
To copy external data for the plant style parameters, see Copying external plant data.
Edit the by style and by instance settings as described in Custom plug-in object styles without catalog options.
To share edits with other users or other files, including saving them to the user and workgroup library folders, see Creating custom resource libraries and Exporting resources.
