LandmarkReplacing plant style graphics
You can replace the Top/Plan and/or 3D graphics used to represent plants in a drawing; for 3D graphics, you can select from several different image sources. Plant graphics are defined by the plant style, and changes affect all plants in the drawing that use the style. While you can't change graphics for individual plant instances, you can introduce variation into the display of plants in a drawing; see Plant settings: Appearance pane.
Alternatively, you can edit the symbols the graphics are based on; see Editing plant style graphics.
To replace plant style graphics:
Do one of the following:
In the Edit Plant Style dialog box Graphics pane, click Replace Current Graphics in the Top/Plan or 3D Graphics section.
In the Plant Style Manager, move the cursor over one or more plant style rows to edit. In either the Top/Plan Graphics column or the 3D Graphics column, click the pencil icon, and then select Replace Top/Plan Graphics or Replace 3D Graphics. Replacing geometry does not affect the plant style's spread or height; you can batch replace the graphics for multiple styles at once.
The Replace Top/Plan Graphics or Replace 3D Graphics dialog box opens. The available options vary depending on the view, and for 3D graphics on the replacement method selected.
Parameter
Description
Top/Plan graphics
Replace with Top/Plan symbol
Select a new symbol from the Resource Selector
Current and new plant graphic previews
Displays the current graphic and previews the new one
3D graphics
Select a replacement method, and then make the selections and set the parameters specific to that method
Generate 3D graphics
Replace with Generated Graphics
3D geometry can be automatically generated based on parameters, creating a suitable representation of the plant style in 3D views.
Spread/Height
Displays the plant style's spread and height for reference
Canopy Shape
Select a general shape for the tree canopy; the preview dynamically displays the shape
First Branch Height
Enter the height where the trunk ends and the canopy starts, or select Default, which starts the spread at 1/3 of the total height
Trunk Girth
Enter the trunk girth; if no value is entered, a default value is calculated based on the plant's spread and height
Canopy Class
To control appearance and visibility, select a class from the list of classes present in the drawing, or create a new class. Alternatively, you can edit the 3D graphic later and edit attributes directly.
Trunk Class
Maxon Plant 3D graphics
Replace with Maxon Plant Graphics
Click Select Plant to open the Maxon Asset Catalog dialog box, to select a plant and specify its seasonal and appearance settings. See Adding 3D plants from Maxon Plant.
Existing 3D model
Replace with a 3D Model
Select a plant 3D symbol from the Resource Selector
Image prop from image
Replace with an Image Prop from the Image
Select whether to get the replacement image from Vectorworks content or from an external file, and then select the image from the Resource Selector or browse to locate the image. The image must have a transparent background/alpha channel. The image can be created using the AI Visualizer; see Generating AI images.
New Graphics
Select the view to display in the replacement graphic preview
Apply this value to
When the dialog box is accessed from the Plant Style Manager, select whether to apply the replacement to only the plant style from which the dialog box was opened, to all selected plant styles, or to all plant styles in the file
For 3D graphics, select the replacement method; for 2D graphics, replacing the graphic with a Top/Plan symbol is the only option.
Select the new plant graphic source and/or set the parameters, as required by the selected replacement method. The new graphic is previewed.
If the dialog box was opened from the Plant Style Manager, select which plant styles to apply the new graphic to.
Editing plant styles
Plant settings: Graphics pane
Plant Style Manager
